TF904/999 Differences and Swap Info - JeepForum.com
post #1 of 4 Old 11-04-2011, 12:25 AM Thread Starter
TA-YJ
My buddy has a 4cyl auto with the 904 in it. Unfortunately the trans wasnt good anymore and he has to get a new one. He found a 999 for a good price, but for some reason the 904s are 3x the price around here. He was saying because of info that he had heard he would have to switch the axles, get an adapter plate, and use a different transfer case etc. From doing some research it doesnt seem like there would be anything near that much needed. So far all I have found the bellhousing needs swapped and driveshafts need swapped due to length. I thought Id ask the experts on here what all is needed to do the swap. Thanks for the info
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
post #2 of 4 Old 11-04-2011, 02:07 AM
94chb
i have a 999 and the bell housing is all one piece with trans. so not sure where you got your info from. also the reason the 904 costs more is cause they are alot more rare and hard to find. tell your buddy to just take his trans and have it rebuilt and reinstall it.
94chb is offline
post #3 of 4 Old 11-04-2011, 10:00 PM Thread Starter
TA-YJ
Haha just shows some of the misinformation thats rolling around the internet. I realize why the 904 is so much more expensive. Still, what all would be required to swap the two?
1992 YJ 2.5L
TA-YJ is offline
post #4 of 4 Old 11-04-2011, 10:02 PM
94chb
an adapter plate (if they even make one, which i highly doubt) 999 trans with torque converter, matching transfer case and may have to shorten/lengthen driveshafts
94chb is offline
AX5 swap in TF904 wrench0001 YJ Wrangler Technical Forum 0 01-22-2011 03:14 PM
Lookin' for TF904 Tranny Info. CK3 TJ Wrangler Technical Forum 0 10-31-2010 05:47 PM
putting a TF904 behind a 4.0 postaldave YJ Wrangler Technical Forum 3 09-08-2010 07:07 PM
Need info about differences between a YJ and CJ Hard Top sprowley YJ Wrangler Technical Forum 16 08-28-2009 10:15 PM
Anyone have info on V8 swap BombThreat YJ Wrangler Technical Forum 7 10-02-2006 11:01 PM
