TF-999 Transmission - JeepForum.com
post #1 of 5 Old 04-12-2010, 12:19 PM Thread Starter
SkullTripper
1987 YJ Wrangler
TF-999 Transmission
So I found out what transmission I have.. but while I was out there checking I noticed a flat gray liquid on the bottom of the transmission bolt and the bottom of the transmission what could this be?
Its a Jeep thing....
My 1987 Jeep Wrangler Build..
SkullTripper is offline
post #2 of 5 Old 04-12-2010, 01:56 PM Thread Starter
SkullTripper
1987 YJ Wrangler
post #3 of 5 Old 04-12-2010, 02:19 PM
ElvisV04290
ElvisV04290's Avatar
9 times out of 10 I find it's engine oil that has dripped down the block and onto the trans on it's way to the road. And it does change color on the way down mixing with all the dirt and stuff.
I would say check the condition of your fluids (so you know one of them is not contaminated) and then wash the engine and trans, that way you can identify where the drip is coming from when it comes back.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #4 of 5 Old 04-12-2010, 02:21 PM Thread Starter
SkullTripper
1987 YJ Wrangler
Well I thought aboutt sprayin degreaser on it and just hosing it down but I don't want to mess anything up.. how would I got about cleaning it up?
post #5 of 5 Old 04-12-2010, 02:28 PM
ElvisV04290
I use the Black Magic Engine Cleaner, it says it's safe for electronics. So I just put a bag over the carb and spray down the engine with the cleaner, let it sit for a min per the instructions, and then hose off. Been doing it for years without a problem. Makes everything look nice under the hood
transmission. Is it going out? Ej132 TJ Wrangler Technical Forum 4 10-18-2009 09:48 AM
Installing transmission: to install transmission and t-case as a unit or separately? Arron TJ Wrangler Technical Forum 8 10-03-2009 05:10 PM
Transmission Help leukus TJ Wrangler Technical Forum 0 04-19-2009 08:02 AM
Transmission Id dave's jeep TJ Wrangler Technical Forum 4 08-21-2008 06:27 PM
new transmission going in... advice for transmission n00b? VABYJ YJ Wrangler Technical Forum 5 07-10-2007 08:43 PM
