TF 999 isn't shifting correctly - JeepForum.com
post #1 of 7 Old 07-11-2013, 04:47 PM Thread Starter
jeepnrover
So my 95's tranny seems to be acting up. It shifts fine at low to moderate acceleration, but lately it doesn't seem to dislike 2nd to 3rd upshifts and downshifts. The engine seems to rev to about 4000 before finally deciding to shift. I checked the fluid level and color, both look good, no signs of contamination. I had it flushed back in april. It ran fine, albeit shifting a bit firm up until recently. Any ideas?
[]lllllll[] 1995 Sahara edition
Previous Jeep: 1991 Islander edition
ARB bull bar, Ground Pounder Fab rear bumper, OME kit with MORE 3/8" booms, 31" BFG A/T's, etc.
jeepnrover is offline
post #2 of 7 Old 07-11-2013, 04:59 PM
jokerchief462
Do you know what a modulator valve is or does. If your trans has one worth a try. Check it on google.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 7 Old 07-11-2013, 06:31 PM
jay-h
That trans does not have a vacuum modulator but there is a linkage between the throttle and the trans. Check that it is working properly.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is online now
post #4 of 7 Old 07-11-2013, 08:55 PM
XJ93
Adjust your TV cable and forward band adjustment. I just had the same issue with my 95 and upon many suggestions doing both of those took care of the issue. The forward band is easy to do as it is accessed from outside the trans so no worries about dropping the pan. The TV cable takes 30 seconds once you open the hood.
XJ93 is offline
post #5 of 7 Old 07-11-2013, 09:05 PM
XJ93
TV Cable is the one with the red button on it that links to your throttle body. Push in the red button, open the tb wide open and snap it shut. The plastic sleeve on the cable should have moved and should now be in the correct location.
Band Adjustment from the FSM:
FRONT BAND ADJUSTMENT
The front (kickdown) band adjusting screw is
located on the left side of the transmission case
above the manual valve and throttle valve levers.
(1) Raise vehicle.
(2) Loosen band adjusting screw locknut (Fig. 179).
Then back locknut off 3-5 turns. Be sure adjusting
screw turns freely in case. Apply lubricant to screw
threads if necessary.
(3) Tighten band adjusting screw to 8 Nm (72 in.
lbs.) torque with Inch Pound Torque Wrench
C-3380-A, a 3-in. extension and 5/16 socket.
(4) Back off front band adjusting screw 2-1/2 turns
for the 30RH and 2-1/4 turns for the 32RH.
(5) Hold adjuster screw in position and tighten
locknut to 41 Nm (30 ft. lbs.) torque.
(6) Lower vehicle.
XJ93 is offline
post #6 of 7 Old 07-13-2013, 12:16 PM Thread Starter
jeepnrover
In working with the TV cable button, it doesn't appear to want to move or stay depressed. Do you hold it down while manipulating the tb?
(1) Raise vehicle.
(6) Lower vehicle.
post #7 of 7 Old 07-13-2013, 02:08 PM
XJ93
Yes, hold it down
XJ93 is offline
