Test an O2 sensor - JeepForum.com
post #1 of 22 Old 04-11-2011, 05:55 PM Thread Starter
scifone
Learns the hard way
scifone's Avatar
Test an O2 sensor
How do you test an O2 sensor to make sure it's functioning properly? I'm getting about 11mpg and I'm going through everything that could be causing this bad of mileage to try and eliminate it. I've already done cap, rotor, plugs, wires, fuel filter and air filter. I'm going to pull off my throttle body and clean that out as well as all the sensors.
Any other suggestions on improving my mpg will be greatly appreciated! I'm not expecting 20+ but I would like to get back to around 14 or so.
Thanks!
Robby
Edit:
Also I do have a small exhaust leak in the manifold and I have a replacement on the way.
scifone is offline
post #2 of 22 Old 04-11-2011, 06:17 PM
Nibbley15
When I replaced my intake/exhaust gasket, and welded my cracked manifold my MPG went up a bit. I haven't taken an exact measurement, but before driving back and forth to work prior to fixing I was almost empty after 2 weeks, this time I'm still over 3/4 tank.
Nibbley15 is offline
post #3 of 22 Old 04-11-2011, 06:32 PM
JOExFROMxNY
From the 1994 Wrangler / Cherokee FSM. see if these help:
02 sensor info from 1994 factory service manual_1.jpg   02 sensor info from 1994 factory service manual_2.jpg   02 sensor info from 1994 factory service manual_3.jpg
JOExFROMxNY is offline
post #4 of 22 Old 04-12-2011, 05:48 AM Thread Starter
scifone
Learns the hard way
scifone's Avatar
That seems like a huge improvement. My leak isn't horrible or anything but I can certainly tell it's there. I hope to see an improvement like that.
Thanks! That's a huge help. If I am going to replace the O2 sensor what brand would you guys recommend?
scifone is offline
post #5 of 22 Old 04-12-2011, 06:34 AM
oldtime_ironman
I prefer NAPA or Bosch (if available). FWIW the O2 sensor is pretty easy to remember: You should roughly see between 3/10 of a volt (300mV) and about 8/10 of a volt (800mV) on the sense wire depending on warm-up and running conditions. It should vary over time with temperature, throttle opening, etc. All measured to a ground point or batt negative. Only one wire is a sense wire; the other wires are for the heater that is built into the sensor, so don't be fooled.
oldtime_ironman is offline
post #6 of 22 Old 04-12-2011, 07:16 AM
Que89YJ
Scifone, do you work for Sprint? Its likely the O2 sensor, the cheaper generics work ok too, you just have to swap the electrical connectors on them.
Que89YJ is offline
post #7 of 22 Old 04-12-2011, 08:11 AM Thread Starter
scifone
Learns the hard way
scifone's Avatar
Thanks! That's very helpful. I'll test it out later today.
No, I am actually still in college. Why do you ask? I definitely like cheaper. Thanks.
scifone is offline
post #8 of 22 Old 04-12-2011, 08:34 AM
Que89YJ
I had a friend that just took a job with Sprint in KC. They moved in somewhere around you in Lawrence. Scifone sounded like a knock on sciphone.
Que89YJ is offline
post #9 of 22 Old 04-12-2011, 08:43 AM Thread Starter
scifone
Learns the hard way
scifone's Avatar
Haha got ya. Sorry man. Thanks for the input though.
scifone is offline
post #10 of 22 Old 04-12-2011, 10:26 AM
Nibbley15
I wasn't expecting that much of an improvement either, but efficiency is efficiency.
post #11 of 22 Old 04-12-2011, 03:03 PM Thread Starter
scifone
Learns the hard way
scifone's Avatar
I hope I get that kind of improvement. I should be getting a new manifold from 1A Auto this afternoon. I'll report back with my findings.
scifone is offline
post #12 of 22 Old 04-12-2011, 03:20 PM
thebeast64
I changed my exhaust manifold on Sunday and so far, the only improvement besides the sound quality is increased throttle response at higher RPM and from a dead stop. I havent had enough time to see any improvement in gas mileage, but since I got this one APN Header our findings would be different anyways. Oh and be prepared with an angle grinder to get that manifold to fit properly. I had to grind off 1/8th of an inch from the outside of both sides of every intake port in order to get it to slide onto the head dowels.
thebeast64 is offline
post #13 of 22 Old 04-12-2011, 05:17 PM Thread Starter
scifone
Learns the hard way
scifone's Avatar
You had to grind the header in the link you provided or the one that 1A Auto sells?
scifone is offline
post #14 of 22 Old 04-12-2011, 05:31 PM
Sleuthhound
I got my exhaust manifold from 1aauto and had no issues installing it. You can find my write up on it in the write ups section.
Sleuthhound is offline
post #15 of 22 Old 04-12-2011, 05:50 PM Thread Starter
scifone
Learns the hard way
scifone's Avatar
I've read through your writeup more than a couple times. Good work!
scifone is offline
how do I test my '94 Wrangler MAP sensor? castaway74 YJ Wrangler Technical Forum 16 01-18-2012 06:03 PM
Oil Pressure Sensor Test RLD831 TJ Wrangler Technical Forum 4 03-16-2010 04:51 PM
How do I test a Throttle Position Sensor? HELP! SamzJeep YJ Wrangler Technical Forum 22 11-30-2009 12:05 PM
Sensor test data... dos0711 YJ Wrangler Technical Forum 3 07-31-2009 03:11 PM
Cam Position Sensor - Is there a test? motobob13 TJ Wrangler Technical Forum 3 03-10-2008 02:53 PM
