test a coil?? - JeepForum.com
post #1 of 9 Old 05-03-2011, 06:22 PM Thread Starter
Djsthe1
test a coil??
Is there a way to test a coil to see if it is bad? What voltage should you get from the coil?
Djsthe1 is offline
post #2 of 9 Old 05-03-2011, 06:31 PM
OOXTEME
Here ya go!
http://youtu.be/rJYJ3KvPhhY
Or...
http://youtu.be/eKWsI2vNxPs
Originally Posted by ZeroGravity View Post
People really drive with the top down and the A/C on??
94 Yj 350 700R4 Swap with Ford 8.8 in progress, 3" BDS Lift, 1" Shackels, 3" Body, Rhino Lined Tub
OOXTEME is offline
post #3 of 9 Old 05-03-2011, 07:52 PM Thread Starter
Djsthe1
OK so the first test would be the same as turning the key on and removing the wire from the top of the distributor cap and putting it near a ground, which I did with coil and a spare coil and nothing. The second I am guessing that by testing the Ohms, if it is a bad coil it will not read any Ohms?
Djsthe1 is offline
post #4 of 9 Old 05-04-2011, 05:41 AM Thread Starter
Djsthe1
Bump...
Djsthe1 is offline
post #5 of 9 Old 05-04-2011, 05:51 AM
Louie4
Your Haynes or Chilton's manual should have the acceptable readings to see if it's bad or not. If you don't know you can take it to Autozone and they'll test it for free, probably even try to sell you a new one if its bad.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 9 Old 05-04-2011, 06:05 AM Thread Starter
Djsthe1
Ahh.. good old trusty Haynes manual.. I forgot all about that..
Djsthe1 is offline
post #7 of 9 Old 05-04-2011, 12:09 PM Thread Starter
Djsthe1
OK so the Ohm level on the coil is 1.5 but still no spark. Took the CPS off, all looks well, cleaned it off and reinstalled. Still nothing, is there a way to check the CPS to see if it is bad?
Djsthe1 is offline
post #8 of 9 Old 05-04-2011, 01:06 PM
Louie4
I think there is a continuity test you can perform but I'm not sure. Have any buddies with the same motor as your jeep? You could try swapping it out.
So there's no spark from the coil to the distributor? If not I'd look towards the CPS like you said.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 9 Old 05-04-2011, 01:21 PM Thread Starter
Djsthe1
No buddies with this motor, I have a spare 95 but the connectors are different on the the newer ones. I looked through the Haynes manual and found a test for the CPS, not sure I understand it but will try it.
Djsthe1 is offline
How to test the coil? nhlx38 YJ Wrangler Technical Forum 4 08-09-2010 02:27 PM
4.2 coil test grimjeeperyj14 YJ Wrangler Technical Forum 1 09-26-2009 11:09 AM
Coil test incredibull TJ Wrangler Technical Forum 1 04-29-2009 07:47 PM
How do I test a ign coil wire 91-2.5l dynamic098 YJ Wrangler Technical Forum 6 03-03-2009 06:33 PM
Test a coil? drmaxdc YJ Wrangler Technical Forum 1 08-09-2004 12:29 AM
