Temperature gauge sending unit - JeepForum.com
post #1 of 14 Old 08-12-2013, 05:19 PM Thread Starter
CBinDC
Does anyone know where the sensor that drives your temp gauge is located? I have '89 4.2L.
CBinDC is offline
post #2 of 14 Old 08-12-2013, 05:52 PM Thread Starter
CBinDC
Can anyone help me? My temp gauge is reading in the red after only driving for a few minutes. The radiator is full and so is the reservoir. I think my sensor has gone but I don't know where it is. My gauge is a one year old autometer and has worked accurately until recently. My guess is the sensor.
CBinDC is offline
post #3 of 14 Old 08-12-2013, 06:06 PM
rocketboy
rocketboy's Avatar
Back of the intake manifold behind the carburetor. Just right of the valve cover. Has a single lead on top.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is offline
post #4 of 14 Old 08-12-2013, 06:54 PM
Old4X
1990 CJ7
It is on the cylinder head itself, driver side near firewall.
There are 2 sensors on the intake, they are for the computer: knock sensor and temp sensor (does not drive gauge, for computer only)_
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 14 Old 08-12-2013, 06:59 PM
Que89YJ
Ground the sensor wire to the block and the guage should go to 0. If it does then your sensor is bad. If it doesn't then you have a wiring issue.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 14 Old 08-13-2013, 01:15 PM Thread Starter
CBinDC
Originally Posted by Que89YJ
Ground the sensor wire to the block and the voyage should go to 0. If it does then your sensor is bad. If it doesn't then you have a wiring issue.
How do you do this without screwing up the fitting on the end of the wire? It's a cap that fits over the threaded part of the sensor.
CBinDC is offline
post #7 of 14 Old 08-13-2013, 01:31 PM
Old4X
1990 CJ7
Use a #8 machine screw, 1 inch or longer
Old4X is offline
post #8 of 14 Old 08-13-2013, 01:44 PM Thread Starter
CBinDC
Thanks for the info but I was referring to how to ground the wire without screwing up the fitting.
CBinDC is offline
post #9 of 14 Old 08-13-2013, 01:45 PM Thread Starter
CBinDC
I'm trying to determine of the wiring is bad or the sensor.
CBinDC is offline
post #10 of 14 Old 08-13-2013, 02:22 PM
XJ93
Put the screw in the open end of wire, touch screw head to engine block. It won't screw up the terminal.
XJ93 is offline
post #11 of 14 Old 08-13-2013, 02:27 PM Thread Starter
CBinDC
Great idea. Thanks.
CBinDC is offline
post #12 of 14 Old 08-13-2013, 02:44 PM
XJ93
Thank Old4X, it was his idea.
XJ93 is offline
post #13 of 14 Old 08-13-2013, 02:51 PM Thread Starter
CBinDC
I didn't get that at all. Haha I can be a little slow sometimes. Thanks for your patience.
CBinDC is offline
post #14 of 14 Old 08-13-2013, 03:29 PM
XJ93
No prob
XJ93 is offline
