temperature gauge - JeepForum.com
post #1 of 4 Old 10-31-2001, 07:29 PM Thread Starter
nomad20012
temperature gauge
My yj cosistently runs at around 100 on the temp gauge. Is this normal? Its a 4 banger and I thought it was a little high.
nomad20012 is offline
post #2 of 4 Old 10-31-2001, 10:08 PM
JeepTodd
I have a 6 cylinder but your temperature should be around 190 - 200 degrees. If your only at 100 degrees then your thermostat needs to be replaced. Its easy and about $5.00 to replace.
1987 YJ, 4" lift, 33 x 12.5's, 4.2l
2001 TJ, 4" lift, 33 x 12.5's, 2.5l, air raid intake, air raid TBS
JeepTodd is offline
post #3 of 4 Old 10-31-2001, 10:15 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
$5 american works out to about $25 canadian .. PartsSource, CanadianTire, AutoValue and Napa all carry them.
Its a fairly easy job to do .. if you have the tools and time. If you are in the Calgary area, let me know and I might be able to squeeze some time to give you a hand if you need it.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #4 of 4 Old 10-31-2001, 11:32 PM
sturgman
My gauge doesnt even register a temp..It's been like this for over a year or so.Whats up with that?? Oh yeah, for about a month before it went out it would move around extatically...
sturgman is offline
Temperature gauge Jblood YJ Wrangler Technical Forum 16 08-23-2012 02:22 PM
My temperature gauge is at zero ? somar YJ Wrangler Technical Forum 0 11-17-2008 10:51 AM
Temperature Gauge mxracer513 YJ Wrangler Technical Forum 13 05-15-2008 12:26 AM
Temperature Gauge rammer YJ Wrangler Technical Forum 4 04-29-2004 09:47 AM
Oil Temperature Gauge smok3y YJ Wrangler Technical Forum 4 10-10-2003 06:10 PM
