Temperature Gauge - JeepForum.com
post #1 of 14 Old 03-01-2008, 09:14 PM Thread Starter
mxracer513
Temperature Gauge
Temp gauge was acting up, working sometimes and sometimes not. Now it doesn't work at all anyway to test the sending unit? the themostat is opening fine i'm just always showin 0* on the gauge
any ideas?
thanks
My Dually CJ Restoration
../|,[____],
.i.---L-[]IIII[]-
()_) ()_)-o-)_)
KB3RDF ..... Yellow Jeep Club Member # 513
mxracer513 is offline
post #2 of 14 Old 03-01-2008, 10:35 PM
lmrsprt
sending unit check the wire conection also
Yeah, I think we're screwed. There are not nearly enough of us and time is running out fast. One day we will tell our grandchildren what it was like to have once been free. They'll likely think us demented.
lmrsprt is offline
post #3 of 14 Old 03-02-2008, 07:17 AM Thread Starter
mxracer513
Wire connections are all tight. I ws thinking it was the sending unit, is there any other way to test other than to just buy a new one?
../|,[____],
.i.---L-[]IIII[]-
()_) ()_)-o-)_)
post #4 of 14 Old 03-20-2008, 10:08 PM
DIZBROW
I am having the same problem. But mine goes up to 240 about 5 min after start-up. I checked the waterpumb with a laser temp gauge and it only reads 135. It is a new sender and a new aftermarket gauge. Sender came the gauge. The stock one starting messing up when i tried to move the needle on my gas gauge. So i replaced the gas gauge and replaced temp gauge with sending unit and ran a new wire for it.
DIZBROW is offline
post #5 of 14 Old 03-21-2008, 05:10 AM
Alfons
Keep in mind that you have two senders/sensors on the YJ 4.0 liter engine. The one at the front in the thermostat housing is the sensor for the ECU and the one at the back of the block (top, drivers side, one wire attached) is for the gauge - you don't see the temperature the computer is seeing.
Both units are testable if you have a multi-meter - the resistance (ohms) changes in direct proportion to the temperature, but I don't have my manuals handy so I can't tell you what the readings should be.
Alfons is offline
post #6 of 14 Old 03-21-2008, 07:30 AM
bamato
bamato's Avatar
Why wouldn't you replace it? I believe I bought mine at autozone for 12 dollars.... Just seems a lot easier than trying to figure out readings and such on a tester.
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #7 of 14 Old 03-21-2008, 11:27 AM
DIZBROW
Update just took mine out and it stays at 240 again when i hit the laser temp on it know where on the engine is over 200?
DIZBROW is offline
post #8 of 14 Old 03-23-2008, 07:53 AM
DIZBROW
Does anyone know only thing i can think of it sender....
DIZBROW is offline
post #9 of 14 Old 03-23-2008, 06:45 PM
sg93yj
on the 1993 thermistor located on top of the engine block nearest the firewall. Here are some resistance measurements you can take across it.
100 deg F = 1365 ohms
210 deg F = 115 ohms
240 deg F = 55.1 ohms
Source of info 1993 FSM
sg93yj is offline
post #10 of 14 Old 03-24-2008, 05:57 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Try grounding out the lead from the gauge. If the gauge maxes out then the gauge is good and the sender is junk.
laybackman is offline
post #11 of 14 Old 03-24-2008, 06:35 PM
DIZBROW
See i have always been told just to pull the wire off the sender and if it drops out the gauge is good thanks guys i will go check right now.
DIZBROW is offline
post #12 of 14 Old 03-24-2008, 06:36 PM
DIZBROW
Sorry dont know if it matters but before i put it in i checked it and it was full resistance my mutl would read 1
DIZBROW is offline
post #13 of 14 Old 03-24-2008, 07:11 PM
DIZBROW
ok somthin funky when i did it i had my multi meter set on 200K the i tested one why it was a -36 anf when i switched the leads it went to 1 I tried the ground out the gauge and it pegs it so i know it is not that. I think i will take it back and get another one. Does anyone know what it should read right out of the box.
DIZBROW is offline
post #14 of 14 Old 05-15-2008, 12:26 AM
chaddo78
I had a similar problem, replaced T-stat, and sending unit, reading 260 until I tap it, goes to 200-210. I'm gonna pull the guage and clean the connecter.
chaddo78 is offline
Temperature gauge Jblood YJ Wrangler Technical Forum 16 08-23-2012 02:22 PM
My temperature gauge is at zero ? somar YJ Wrangler Technical Forum 0 11-17-2008 10:51 AM
Temperature Gauge rammer YJ Wrangler Technical Forum 4 04-29-2004 09:47 AM
Oil Temperature Gauge smok3y YJ Wrangler Technical Forum 4 10-10-2003 06:10 PM
temperature gauge nomad20012 YJ Wrangler Technical Forum 3 10-31-2001 11:32 PM
