Temperature gauge - Page 2 - JeepForum.com
post #16 of 17 Old 08-18-2012, 05:17 PM
jojojeep1
i changed my tranny fluid than put it all back togather and my temp gauge stoped working also,it ended up that the tranny droped down to far and the wire pulled of the sensor ,easy fix . thank GOD i get a lot of those no money easy fixes.
jojojeep1 is offline
post #17 of 17 Old 08-23-2012, 02:22 PM
rm56
Originally Posted by Jblood View Post
Today I was driving and noticed that my temperature gauge had suddenly stopped working. I drive a 1987 Wrangler and I'm proud to have one. What I am wondering is where the sending unit is(So I can Work on it) or what could have caused this problem any insight would be great.
Thanks
-John
I don't know which engine you have. I have a straight six in my 91 YJ. On that engine the sending unit to the guage is at the rear of the head on the drivers side. If you climb up and bend way over the block you'll see it. It's a small probe that has an "L" shaped connection that just pushes on like a spark plug wire. The temp sensor up front near the thermostat is the coolant sensor for the computer, not the gauge. Also it does'nt hurt to take your gauge cluster out and clean the contacts, and the one plug to the harness.
rm56 is offline
My temperature gauge is at zero ? somar YJ Wrangler Technical Forum 0 11-17-2008 10:51 AM
Temperature Gauge mxracer513 YJ Wrangler Technical Forum 13 05-15-2008 12:26 AM
Temperature Gauge rammer YJ Wrangler Technical Forum 4 04-29-2004 09:47 AM
Oil Temperature Gauge smok3y YJ Wrangler Technical Forum 4 10-10-2003 06:10 PM
temperature gauge nomad20012 YJ Wrangler Technical Forum 3 10-31-2001 11:32 PM
