Quantcast Temperature gauge - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Temperature gauge
Old 10-09-2007, 02:34 PM   #1
Jblood
Temperature gauge
Today I was driving and noticed that my temperature gauge had suddenly stopped working. I drive a 1987 Wrangler and I'm proud to have one. What I am wondering is where the sending unit is(So I can Work on it) or what could have caused this problem any insight would be great.
Thanks
-John
Jblood is offline   Reply With Quote
Old 10-09-2007, 10:50 PM   #2
rwinter
ok, got it fixed. first tried grounding the original wire going to sending unit, this should have pegged the guage if guage was good and the wire wasnt broke somewhere between the sending unit and guage cluster. nothing happened so i spliced into solid purple wire on guage cluster and tried grounding it, the guage pegged so i ran the new wire that i spliced through the firewall spliced it to the boot and reconnected. works fine now.
this is from a post i had up when mine quit working.
the sending unit is on the back of the motor on the drivers side on top next to a head bolt. should have one wire with a rubber boot connector.
if you have any problems let me know, maybe i can help.
rwinter is offline   Reply With Quote
Old 10-09-2007, 10:54 PM   #3
rwinter
i am taking for granted you have a 258 in your rig. you need to fill out your profile so we know what you got.
Old 10-09-2007, 11:04 PM   #4
kharmajavah
If it's anything like mine (none of the gauges worked when I bought my 90; the temp and oil pressure gauge worked only intermittently), this is an easy fix.
I removed the cluster, removed the gauges, cleaned all of the terminals to remove corrosion, then replaced everything (dielectric grease!) and made certain that the connections were good and tight when I reconnected everything. Everything's been kosher for a year now.
Also, keep an eye out for shorts on the plastic circuit board on the back of the cluster as well - I had to replace mine due to a couple of shorts.
kharmajavah is offline   Reply With Quote
Old 10-10-2007, 01:44 PM   #5
Jblood
yea your assumption of the 258 was correct, sorry for not having the information, I'm new
Old 10-10-2007, 07:39 PM   #6
Jblood
thanks for the help, i plan on cleaning the contacts since that seems to be the problem (it worked for about 10 minutes of my drive to school) so i know the sender and gauge work i guess its just dirty being 20 years old and all
thanks
John
Old 10-10-2007, 08:09 PM   #7
kharmajavah
I'd bet that solves your problem. Don't overdo it, but also don't be afraid to make the nut holding the circuit board to the gauge nice and tight...mine felt good at first, but it turned out they needed an extra turn or so.
Old 10-10-2007, 08:15 PM   #8
Jblood
Alright thanks I guess I'm not going too far until the weekend because I don't have time until Saturday
Old 01-04-2008, 04:45 PM   #9
lstuckey1
I have a little bit of info to add to this thread. I also had intermittent temp, gas and oil pressure on the gauges. I took the gauge cluster out and removed the nuts on the back of each black plastic terminal plug. When I removed the plugs I found some corrosion at the base of the posts where the plug makes contact with the terminal on the circuit board. I cleaned all the posts and contact points (essentially every brass part that touched another brass part) with a scotch brite pad. I also got to thinking about what might be going on inside the plug holes in the back of the gauges. I shined a flashlight inside the holes and it looked pretty corroded. I took a Q-tip (white cotton ones not plastic) and cut off one end with side cutters. I then twisted the cut end into the hole in the back of the gauge and it came out pretty black. Be careful you don't twist the Q-tip off in the hole, just a note even though they are very sturdy. After cleaning all the holes I put everything back together with dielectric grease and the dash works great. No more bouncing gas gauge and intermittent oil pressure. I don't know if this has been covered before but it won't hurt to mention.
lstuckey1 is offline   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
