Temperature - JeepForum.com
post #1 of 7 Old 08-01-2004, 07:40 PM Thread Starter
90yjjeep
Temperature
I have a 90 model yj with a 258. What does you temp. usually run?
90yjjeep is offline
post #2 of 7 Old 08-01-2004, 08:38 PM
CAJUN_YJ
CAJUN_YJ's Avatar
temp
I think most engines run 190-195
CAJUN_YJ is offline
post #3 of 7 Old 08-02-2004, 08:58 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Mine usually runs around a notch lower than that 210 mark on the gauge.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #4 of 7 Old 08-02-2004, 09:00 AM
talonegress
talonegress's Avatar
mine also runs just below 210 to right at 210.
Current: 2010 Nissan Titan Pro-4X
Past: 1995 Jeep Wrangler Rio Grande
Air Force Jeep Club #1
talonegress is offline
post #5 of 7 Old 08-02-2004, 09:53 AM
edcham
Can anyone tell me where the temperature sending unit is on the six cylinder (1989)?
edcham is offline
post #6 of 7 Old 08-03-2004, 04:53 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Looking at the engine from the front of the Jeep, it's in the back right corner, on the back of the intake manifold. Mine (same engine as you) has a threaded part sticking up which has a rubber boot type of connector that fits over the top of it. If I remember correctly, it's pretty close to the engine block.
post #7 of 7 Old 08-04-2004, 08:24 AM
edcham
Thanks TSHARK. I found it. I think mine's bad.
edcham is offline
At what temperature does your top come off? knipdm01 YJ Wrangler Technical Forum 35 03-25-2008 11:00 AM
Temperature Help CGScotty JK Wrangler Technical Forum 9 08-17-2007 05:28 PM
what temperature? admar2 TJ Wrangler Technical Forum 6 12-02-2005 09:43 AM
help! very hot (temperature) TJ HotTJ TJ Wrangler Technical Forum 9 09-17-2005 02:34 PM
Oil Temperature jetrela TJ Wrangler Technical Forum 1 12-18-2003 07:31 AM
