post #16 of Old 08-18-2011, 01:08 PM
Alfons
On those engines that have no hole tapped for the sender unit, the boss is still there and can be drilled and tapped. I did this on a 2005 4.0 engine block - the hole is for a 1/8" NPT thread. If you decide to drill and tap, be careful not to turn the tap too far into the hole while threading because you'll end up with a loose fit. This is tapered pipe thread, designed to give you a real tight fit when done right. When you drill the hole, it'll open up into the coolant cavity below the boss - any bits of metal that fall into this cavity that you can't retrieve with a magnet will disintegrate in the coolant eventually without harming the engine.
Alfons is offline
post #17 of Old 08-18-2011, 07:21 PM Thread Starter
PFCLinscomb
Nahhh I'm not comfortable with tapping a hole in the block.
But I'm going to just get the Hi-Flow thermostat housing Max suggested, much less work. lol
Times you kick yourself in your own ***: When that stupid Private wakes the whole platoon up by running through the bay screaming "Reveille,Reveille,Reveille!!!!!!!!!!!!!!!!!!! !" And your like "Who the hell put that guy on last fire guard" and then you realize.... You did -.-
PFCLinscomb is offline
tempurature sending unit
temp sending unit? wendell YJ Wrangler Technical Forum 2 07-12-2011 04:53 AM
91 yj temp sending unit venturaf YJ Wrangler Technical Forum 7 07-18-2010 04:28 PM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 09:41 AM
Temp Sending Unit rrclimber YJ Wrangler Technical Forum 7 04-21-2003 10:09 AM
Temp sending unit buzzbomb YJ Wrangler Technical Forum 2 10-04-2002 04:55 PM
You may not post new threads
You may not post replies
