Temp Sender Problem - JeepForum.com
post #1 of 3 Old 11-16-2001, 10:32 PM Thread Starter
dkirsch
Temp Sender Problem
Hey guys. I am a new member and have a electrical problem I just can't figure out. My temp guage on my '90 YJ has never worked since I bought it (few months ago). I checked the wiring behind the guage, and it seems intact. What do I check first? Is there a part that usually goes bad. Any info helps. Also, does anyone have a wiring harness diagram they can email me? The engine is a 4.0 straight six. Thanks for the help.
'90 YJ - mostly stock
dkirsch is offline
post #2 of 3 Old 11-17-2001, 01:09 AM
sturgman
mines out too!! I just ignore it...beer always seems to get in the way!!keep wavin..
sturgman is offline
post #3 of 3 Old 11-17-2001, 06:51 AM
glm 87 wrangler
Ok I have a 256 but mine went out I just replaced it with a add on from advanced auto
did not want to go through the dash deal again.Sent the wire through fire wall put the new sender wire to the side of the engine block near the intake.Took out the old one also replaced with new one.Cost me 15.00 bucks and 10min.easy job.most have universal
plug adapters.hope this helps.I put my new gage near my emerg.brake handle.Ok just got to look down.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
What voltage at coolant temp sender? UnderDog! YJ Wrangler Technical Forum 0 10-01-2009 08:28 PM
Coolant Temp Switch (Sender) rmorrison9773 YJ Wrangler Technical Forum 0 06-01-2009 07:17 AM
Water temp cooling sender zekthecat YJ Wrangler Technical Forum 10 07-26-2008 12:35 PM
oil temp sender. 4.0l sahara TJ Wrangler Technical Forum 2 06-22-2008 10:08 AM
temp guage sender placement? birdman86 YJ Wrangler Technical Forum 3 05-24-2006 04:21 PM
