Temp gauge not working 89 yj - JeepForum.com
post #1 of 12 Old 01-18-2011, 05:32 PM Thread Starter
ckid222
So title says it all. I searched on here and found a write up on how to clean up the circuit board (clock works now) but temp gauge not working. My question is Im pretty sure it worked before I nuttered could that have some thing to do with it? Also is there a way to test if the gauge itself is working? Any help would be appreciated. Thanks
I also have a '89 yj
ckid222 is offline
post #2 of 12 Old 01-18-2011, 07:43 PM
hh65pilot
Nutter bypass should not be a factor. My temp gauge was intermittent until I took the whole cluster out and ran additional grounding wires to all the nagative posts.
hh65pilot is offline
post #3 of 12 Old 01-20-2011, 07:29 PM
Schaef81
Easy way to test. If you have a voltmeter or any device where you can ground the wire to the block the gauge should go to 100% (fully right if sitting in the driver seat). My temp gauge too has gone out on me, just havent had the time to diagnose.
Schaef81 is offline
post #4 of 12 Old 01-20-2011, 08:10 PM
Old4X
1990 CJ7
When you were messing with the wires, did you disturb the temp gauge wire to the sending unit on the back of the head?
I was pulling wire over mine when I Nuttered, and it would be easy to knock it loose.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 12 Old 02-03-2011, 09:20 PM Thread Starter
ckid222
Not sure, do you know what color the wire is or how would I identify it?
ckid222 is offline
post #6 of 12 Old 02-04-2011, 07:20 AM
Que89YJ
This is the temp sensor. Remove the connector and see if the guage deflects. Short the wire to ground and it should go to 0. If it does then you need to replace the sensor. If it doesnt then post back.
Que89YJ is online now
post #7 of 12 Old 02-04-2011, 07:26 AM
Berniebikes
on my 88 it is a purple wire. look here
it runs to the little sensor on the rear of the block beside the valve cover
Berniebikes is offline
post #8 of 12 Old 02-04-2011, 07:30 AM
Que89YJ
Same function. Do the test.
post #9 of 12 Old 12-31-2014, 02:39 PM
timb24540
I have an 89 YJ and same issue that temp gauge does not work. Replaced the temp sending unit, check good continuity on wire from sending unit to cluster, grounded the wire to the - terminal on battery but gauge still does not read above "0". Flushed coolant and did pressure check, all was good. Any ideas?
timb24540 is offline
post #10 of 12 Old 12-31-2014, 03:11 PM
fishadventure
Yes- good chance it's the infamous wonky printed circuit issue. Answers in the faq
shackles or D rings?
wrong words brake the web
cranking IS turning over
fishadventure is offline
post #11 of 12 Old 12-31-2014, 03:50 PM
TippmannA-5
Mine works kind of. I checked the connection on the back of the head but it did not change. I checked the engine temp were the coolant hose attaches to the head with a infrared thermometer and it said it was at 200 degrees while the gauge read what is pictured.
I'm growing rather fond of driving a vehicle with the aerodynamic qualities of a brick.
Yellow Jeep Club Member #4.2
Every time a bird craps on my jeep, I sit on my front porch and eat scrambled eggs to show them what i'm capable of!
TippmannA-5 is offline
post #12 of 12 Old 12-31-2014, 06:32 PM
Que89YJ
It's the connection to the gauge. You can jumper power to it to check function.
Fault codes:
Mean Max pics of everything:
No Start:
Temp Gauge not working. BigLou YJ Wrangler Technical Forum 19 06-19-2014 01:36 AM
95 yj temp. gauge not working danlab825 YJ Wrangler Technical Forum 7 12-28-2012 02:05 PM
Temp gauge not working.. SleddinJeeper YJ Wrangler Technical Forum 32 12-06-2008 02:32 PM
Temp Gauge Working Again RCHavok797 YJ Wrangler Technical Forum 21 12-01-2007 07:21 PM
Temp Gauge not working??????? samahi72 YJ Wrangler Technical Forum 4 04-10-2006 11:45 AM
