Temp gauge needle fluttering - JeepForum.com
post #1 of 2 Old 09-14-2011, 08:39 AM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
I just purchased my first ever Jeep....87 Wrangler Loredo 4.2 MT. When i got her The only gauge that worked was the speedo. I have all the gauges working now but the temp gauge needle flutters around like crazy. When the engine is at an idle the needle settles down to an accurate reading but as soon as the rpms come up it flutters like crazy. I'm guessing it has to do with the voltage but don't know how to fix it.
mudsweatNgearz is offline
post #2 of 2 Old 09-14-2011, 01:25 PM
Que89YJ
Welcome to the forum.
Check the wire going to the temp sensor:
http://www.jeepforum.com/forum/f12/t...orking-687856/
If the wiring is good the there is a writeup on cleaning the contacts for the guage itelf.
Que89YJ is online now
gas gauge needle problem dabjeep YJ Wrangler Technical Forum 13 08-05-2013 04:24 PM
the oil gauge needle is bouncing itsgroll YJ Wrangler Technical Forum 2 01-08-2008 06:17 PM
Son of a ..... gauge needle help.. Did you change out your reds? XabuJr TJ Wrangler Technical Forum 4 01-20-2007 09:52 PM
Speedo gauge needle jumping around (temp dependent) svaughan TJ Wrangler Technical Forum 2 11-19-2005 08:51 PM
Gauge needle screw up tpoag TJ Wrangler Technical Forum 8 06-13-2005 08:38 AM
