temp gauge ??? - JeepForum.com
post #1 of 8 Old 01-04-2004, 06:37 PM Thread Starter
Durbahn
temp gauge ???
In my 91 wrangler. My temp gauge dosent work at all. I tried putting in a new coolant sensor, that didnt help, So i checked the wire from the sensor to the harness behind the cluster, that was good. Now i am looking at the printed circuit on the cluster and it looks good but i dont know how to check it any help would be greatly appreciated
also if i have to replace the printed circuit does anyone know where i can get one or will i have to sell something so i can afford one from the dealership
Also if anyone who reads this has a entire cluster for sale please leet me know, i know this part should be in the wanted section but i didnt want to start a new thread
Thanks
Durbahn
91 sahara
2.5" RE lift
2" shackle lift
32 Super Swamper TSLs
posi lok'd
more to come
http://www.geocities.com/mopar_2005/jeep.html
Durbahn is offline
post #2 of 8 Old 01-04-2004, 06:40 PM
RCHavok797
RCHavok797's Avatar
I was able to pick a gauge cluster up off of ebay.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #3 of 8 Old 01-05-2004, 09:09 AM
RSouth
I just replaced the printed circut on my 89 YJ. I picked up a whole cluster panel for $50.00 at a junk yard. All I needed was the printed circut. A new P C was $40. at the dealer. I installed it this weekend, now all my gagues work!
RSouth
RSouth is offline
post #4 of 8 Old 01-05-2004, 09:23 AM
YoungJeeper
My gauge didn't work before so I asked a repair guy about it he said with the 4.0 L in the jeeps there is 2 coolant sensors one in the back and one in the front... The one in the back driverside is the one for the gauge.... As for the other one i believe its in the front, but not sure. I don't know if that helps you any but figured i'd try
Jeep...My anti drug
1993 YJ Sahara
4.0L with Gibson exaust
2 1/2 inch skyjacker soft ride
sway bar disconnects
no rear track bar
black super top
31 good year a/t s on black american racing rims
year round mud
YoungJeeper is offline
post #5 of 8 Old 01-06-2004, 12:33 PM
rickr
i went to auto zone and spent $15 on a mechanical gauge. tee,d it into the heater hose, and now i have a working gauge!
just an idea.
94 4.0
rickr is offline
post #6 of 8 Old 01-07-2004, 09:12 AM
billetbong
take the wire that clips onto your sensor, jump that to ground, if your temp gauge maxes out your problem is not anywhere in the wiring between the end of the wire and the gauge, its in the sensor. like other guys have already said, just be sure you changed the right sensor.
another problem i personally encountered, which seem unlikely in your case being winter and all. my thermostat actually came apart. so i had no thermostat, well the jeeps gauge would never move because it never had a chance for the coolant to get hot. i just changed the temp sensor one night in a rush and didnt bother to check anything else out. the gauge still didnt work. i was pissed but didnt have time to -=-=-=-=-=-=-=-= with it. a few nights later it got cold out and she wouldnt put out any heat. well lookin at my broken (or so i thought) temp gauge the light bulb finally clicked on and sure enough there was nothing left of my t-stat but the little plate. unlikely for you being winter and you would probably notice the lack of heat, but i figured i toss it in there anyways.
billetbong is offline
post #7 of 8 Old 01-07-2004, 09:57 AM
83iS
I have a similar problem but...My temp gauge works somtimes and somtimes it doesnt, it will go up to the normal operating mark then the next time i start it up the gauge doesnt move at all
Kyle
83iS is offline
post #8 of 8 Old 01-07-2004, 10:32 AM
SundevilYJ
SundevilYJ's Avatar
Kyle
Mine does the exact same thing, but I have been too lazy to attempt fixing it. My oil pressure guage has never worked. I should probably get mechanical guages.
98 TJ 4.0L, Auto D44 3.73 LS
2.5" OME HD springs, Racho 9000 shocks 1.25 JKS BL & BMML, 32 11.50 BFG AT, Eagle Alloy 186
2002 Grand Cherokee Limited (loaded)
4.7L, 4x4, 18" Moda R8, 255x55x18 Yokahama Geolanders
SundevilYJ is offline
89 YJ Temp gauge DOA monkeyhouse YJ Wrangler Technical Forum 3 09-21-2009 10:59 AM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 09:01 PM
temp gauge 1992JeepYJ YJ Wrangler Technical Forum 5 10-30-2006 06:12 PM
temp gauge 1992JeepYJ YJ Wrangler Technical Forum 6 09-28-2006 10:35 AM
temp gauge brad2bw YJ Wrangler Technical Forum 4 08-31-2004 09:27 AM
