temp gauge - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > temp gauge
IRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wd
Unread 01-19-2015, 01:26 PM   #1
Rldevogt
temp gauge
A little history on the jeep. When I bought it the thing would barely drive down the road a lot of my own blood and the knowledge of the people on the forum she drives like a champ-ish.
I did the nutter bypass a couple of months ago and attempted to fix the rigged up wiring the PO did. Ive heard that yjs can pretty much run off of three or four wires and that would be cool but I would like my temp gauge to work.
Attached are the connectors that I thing control the temp gauge. If I am wrong can someone please let me know.
I have taken the dash apart and cleaned the connector connections.
I am in the process of cleaning all of the electrical connections in the engine bay.
As far as I know i have never had an over heating issue but I dont want it to start now.
Any help or ideas would be great.
If I am wrong on the connectors what do these go to and are the important?
Rldevogt is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 06:45 PM   #2
motley-crue
Temp Gauge
The temp sending unit is located at the back of the engine on the drivers side beside the valve cover and behind the fuel rail. It has one wire going into it.
Somewhere between $15-$30 to replace depending on brand.
motley-crue is offline   Reply With Quote Quick reply to this message
Unread 01-20-2015, 12:25 AM   #3
timatoe
timatoe's Avatar
It is on the back driver side corner of the block, but not behind the fuel rail since you don't have one. The temp sender on the manifold tells the computer to go into closed loop, which isn't being used anymore since you did the Nutter. You also need to do something with that CTO valve, can't imagine it's running real well with a massive vacuum leak.
Read through THIS SITE it's for a CJ but will give you a good indication of what's going on with your 4.2, or at least how it used to work pre-Nutter.
timatoe is online now   Reply With Quote Quick reply to this message
