temp gauge - Page 2 - JeepForum.com
post #16 of 26 Old 08-14-2013, 08:33 PM Thread Starter
Tyler980
On the frontside? Or backside in the wiring frenzy?
Tyler980 is offline
post #17 of 26 Old 08-14-2013, 08:46 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
On the front. A couple mins with a screwdriver should do it.
Randonexplosion is offline
post #18 of 26 Old 08-14-2013, 09:20 PM Thread Starter
Tyler980
Alright thanks
Tyler980 is offline
post #19 of 26 Old 08-15-2013, 07:47 AM
Que89YJ
Here is a great link on the cluster repair. Thanks Max! Looks like I am citcelsyd....LOL
Thanks for catching it.
http://www.jeepforum.com/forum/f12/r...er-how-991307/
Que89YJ is offline
post #20 of 26 Old 08-16-2013, 03:15 PM Thread Starter
Tyler980
Cleaned it up and still nothing... the wires seem to be good too... could it just be the sensor or the whole gauge?
Tyler980 is offline
post #21 of 26 Old 08-16-2013, 04:53 PM
Que89YJ
The first link was for temp sensor images using Google. There is a neat trick to searching the forum. Look at this thread to explain how.
http://www.jeepforum.com/forum/f12/f...oogle-1003734/
The second link I posted was for the cluster.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #22 of 26 Old 08-16-2013, 05:31 PM Thread Starter
Tyler980
The cluster is what I cleaned up. No change though.
Tyler980 is offline
post #23 of 26 Old 08-16-2013, 09:22 PM
Que89YJ
You need to use a meter and check the resistance from the connector on the cluster to the connector on the sensor. The other thing to test the guage is to short the pin on the cluster connector wire by putting a needle through the wire and short the wire to ground. I think you should do the resistance check.
Fault codes:
No Start:
Que89YJ is offline
post #24 of 26 Old 08-17-2013, 12:40 PM Thread Starter
Tyler980
Could anyone give me part # for sensor?
Tyler980 is offline
post #25 of 26 Old 08-17-2013, 12:47 PM
Randonexplosion
Deplorable
Napa part number is TS6666. They call it a Temperature Sender. $14
post #26 of 26 Old 08-17-2013, 12:56 PM Thread Starter
Tyler980
Thanks
Tyler980 is offline
