temp gauge - JeepForum.com
post #1 of 26 Old 08-12-2013, 09:42 AM Thread Starter
Tyler980
temp gauge
My 88 yj temp gauge used to work... now it doesn't. Any ideas what I could do to get it back?
Tyler980 is offline
post #2 of 26 Old 08-12-2013, 12:52 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Check the connection at the coolant temp sensor. If that is ok, replace the sensor and/or trace the wiring back as far as possible and look for breaks. It should be a single wire.
Randonexplosion is offline
post #3 of 26 Old 08-12-2013, 01:11 PM Thread Starter
Tyler980
Its the one that sits closer to firewall behind the carb correct?
Tyler980 is offline
post #4 of 26 Old 08-12-2013, 01:21 PM
Randonexplosion
Deplorable
Yep, right next to the valve cover.
post #5 of 26 Old 08-13-2013, 11:38 AM Thread Starter
Tyler980
It looks okay
Tyler980 is offline
post #6 of 26 Old 08-13-2013, 11:44 AM
Que89YJ
With the wire disconnected from the sensor it should be max hot. Disconnect the wire and ground it to the block and it should go max cold. If it does those then the sensor is bad. If it doesn't then the wire or guage is bad.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #7 of 26 Old 08-13-2013, 11:57 AM Thread Starter
Tyler980
Okay thank you. I will try that when I get home.
Tyler980 is offline
post #8 of 26 Old 08-13-2013, 12:47 PM Thread Starter
Tyler980
Pulled it off and no change.
Tyler980 is offline
post #9 of 26 Old 08-13-2013, 03:35 PM
XJ93
Pulled it off, did you ground it? Stick a machine screw in the end of it and touch the screw head to the block and look at the gauge.
XJ93 is offline
post #10 of 26 Old 08-13-2013, 05:42 PM Thread Starter
Tyler980
Ah I didn't I will try that thank you
Tyler980 is offline
post #11 of 26 Old 08-14-2013, 08:40 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Backwards.
Pull wire off = full cold
Ground wire = full hot
The temp sensor is a "TURD" sensor.
Temperature Up Resistance Down
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #12 of 26 Old 08-14-2013, 08:47 PM Thread Starter
Tyler980
I pulled the wire off and used a machine screw and grounded it and the gauge still did nothing.
Tyler980 is offline
post #13 of 26 Old 08-14-2013, 09:07 PM
Randonexplosion
Deplorable
Then I'd say you have an interruption in the wire or a bad gauge. Happy hunting
Maybe you can try to pull the gauge and see of there is any corrosion on it.
post #14 of 26 Old 08-14-2013, 09:18 PM Thread Starter
Tyler980
I'm not really sure how to pull the gauge out.
Tyler980 is offline
post #15 of 26 Old 08-14-2013, 09:23 PM
Randonexplosion
Deplorable
There are a few upper and lower screws on the panel that covers the gauge. After that just a few more screws and it should come out.
