Temp fluctuates w/ new radiator, already burped - JeepForum.com
post #1 of 7 Old 09-19-2010, 08:25 PM Thread Starter
TheGroogruxKing
My radiator was leaking so I replaced it with a used one from a TJ, now my temp fluctuates from 210-225 over and over when the Jeep is running. It will slowly climb to 225 then abruptly drop to 210. I ran it with the radiator cap off to burp it and get air out of the system, and each time it reached 225 the coolant level would rise then a bubble would come out then the coolant level would drop again. I thought that this was working to get the air out, but after an hour of running it this way it was still doing it. How much air could be in there? How long does it normally take to compleatly burp it? Or is there something else wrong? Prior to the radiator swap the temp was steady at 215 or so, other than the leak there was nothing wrong with it.
TheGroogruxKing is offline
post #2 of 7 Old 09-19-2010, 09:00 PM
Old4X
1990 CJ7
Completely burping the cooling system has taken at least 3 total warm up and cool down cycles on my most troublesome install.
I try to park with the front wheels considerably higher than the rear wheels so the cap is as high as possible in the system.
Don't forget to make sure the heater has good flow.
Thermostats can stick and cause temp fluctuations, especially when warming up (temp overshoots normal opening point, then rapidly drops when it finally opens).
Keep after it, you will get it.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 7 Old 09-19-2010, 09:14 PM
moonshinefuel
Put a Robertshaw 190 degree thermostat in it if you have not replaced that yet.
moonshinefuel is offline
post #4 of 7 Old 09-19-2010, 10:29 PM Thread Starter
TheGroogruxKing
I haven't replaced the tstat yet, but I didn't have any problems before the radiator swap, the temp was always steady. I'll try burping it again with the front wheels on ramps this time, hopefully that will get all the air out.
post #5 of 7 Old 09-19-2010, 10:40 PM
AnonymousD
With my Mustang I had to back it into a shallow ditch once to get all the air out. Shouldnt be a problem putting a Jeep in a ditch though. You could probably do the ramps AND the ditch, lol.
AnonymousD is offline
post #6 of 7 Old 09-19-2010, 10:47 PM Thread Starter
TheGroogruxKing
Also, it seemed like there was a lot more air bubbling out with the heater off than there was with the heater on. Is there anything to that? The temp fluctuations were the same, just smaller burps.
post #7 of 7 Old 09-20-2010, 12:31 PM
Matt The Hammer
You're worrying too much with this. Just drive it, park it, let it cool, fill. Few times and you'll get all the air out. Never really had any success with 'burping' it with the cap off and the while thing running. All I do is end up spilling more coolant...
T-stats are cheap. They're also crap. So like 'moonshinefuel' stated, replace it. Easier now than any other time (before it's 10 degrees out!). You should be at 190 anyway. These things don't last forever.
The radiator cap is already at the system's highest point, so air will go there once the t-stat opens while running.
2013 JKU
1995 YJ
Matt The Hammer is offline
Need to replace radiator?--Normal runnning temp. mightydog78 TJ Wrangler Technical Forum 3 08-25-2009 11:41 AM
need a temp fix for a leaking radiator cvaria TJ Wrangler Technical Forum 4 07-05-2009 03:17 PM
post-radiator replacement temp question jessasfella TJ Wrangler Technical Forum 4 03-27-2008 08:31 AM
Radiator thermostat temp probe location Mr. Tobes YJ Wrangler Technical Forum 11 05-24-2006 01:57 PM
temp fluctuates new2jeep YJ Wrangler Technical Forum 14 06-04-2004 09:20 PM
