temp fluctuates - JeepForum.com
post #1 of 15 Old 05-27-2004, 07:16 PM Thread Starter
new2jeep
temp fluctuates
The temp climbs to around 215 to 220 degrees and then quickly drops back to about 195 and then climbs back up. Shouldn't a temp of about 195 be maintained since that is what the thermostat is? I recently replace the radiator because it was due and installed a new radiator cap. Could it be the sending unit? As fast as the temp drops, I can't believe it would cool down 25 degrees that fast.
Any thoughts?
89YJ Sahara, 2" BDS Lift, M.O.R.E. 5/8" Boomerang Shackles, 15"x8" American Racing Baja Wheels, 31x10.5/R15 BFG Mud Terrain KM's, weber, nutter bypass
new2jeep is offline
post #2 of 15 Old 05-27-2004, 08:21 PM
Silver yj
You might have a little air left in the system,if its going up and down that quick its a good chance that you do.
Silver yj is offline
post #3 of 15 Old 05-27-2004, 09:24 PM
ugajeepgirl
Yeah it could be air. It could also be the temp sensor. You can try to "reset" it by unplugging it for awhile then reconnecting it or you can just plunk down the $15 to get a new one. When my temp gauge was acting screwy, turned out to be the sensor so I just replaced it.
Good luck
Silly boys, Jeeps are for girls ;)
A girl and her Jeep: it's a beautiful thing :)
ugajeepgirl is offline
post #4 of 15 Old 05-28-2004, 06:43 AM Thread Starter
new2jeep
Good luck
I don't think it is air in the system. It did this prior to changing the radiator as well. I got a new sending unit on the way. Hopefully this will fix the problem.
Thanks
new2jeep is offline
post #5 of 15 Old 05-30-2004, 08:27 PM
bluYJ
Sounds like a sticking thermostat. Had the same problem a couple years ago. Put a brand new 160 degree thermostat and never had another problem with it.
95 yj, 4 cyl, auto trans, 4 1/2" Rubicon Express extreme duty lift,
33" BFG Muds, 4:88 gears, Detroit's front and rear, Dana 44 rear axle with disc brakes, heavy duty Dodge NP231,SYE, MORE sport cage. Blue Jeep Club Member #61
bluYJ is offline
post #6 of 15 Old 05-31-2004, 04:16 PM
TSEJEEPERS
This might sound like a stupid question but do you have a electric fan that kicks on and off with the temp?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
post #7 of 15 Old 05-31-2004, 08:15 PM Thread Starter
new2jeep
The fan is not an electric fan. I had ordered a new temp sending unit from auto zone but they ordered me a oil sending unit and when I told them that is not what I ordered, they told me they could not get a temp sending unit. So I ordered one from Quadratec and while I was at it, I ordered a new thermostat. By the time I am done, everything on this jeep will be new. But what the H#$l, it is fun to tinker with.
new2jeep is offline
post #8 of 15 Old 06-01-2004, 07:14 AM
RCHavok797
RCHavok797's Avatar
I was able to get a temp sending unit from Advance Auto. Make sure you order the correct one. There is a temperature sensor that relays info to the computer that is located on the thermostat housing and the temperature sending unit for the gauge is located on the back of the engine block which is the one you need.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #9 of 15 Old 06-02-2004, 08:00 PM
archie
Let us know if this fiixes the problem mine does the same thing I jus assumed it was the thermostat opening and letting the coolant from the rad to ciculate dropping the temp. I think the sticking thermostat might be the answer.
archie is offline
post #10 of 15 Old 06-02-2004, 08:16 PM
ugajeepgirl
Its weird that you guys haven't been able to purchase the temp sending unit aka temp sensor at a local auto parts store. I picked mine up at a local Autozone for $15.
post #11 of 15 Old 06-02-2004, 08:18 PM
ugajeepgirl
Archie,
Try unplugging the temp sending unit for a bit to let it reset itself. Sometimes this works, sometimes it doesn't.
post #12 of 15 Old 06-03-2004, 06:41 PM Thread Starter
new2jeep
I just replaced the temp sending unit. Same thing happens. When I ordered the sending unit, I also ordered the thermostat, so tomorrow I will install that and try that. I'll let you know if that fixes the problem.
new2jeep is offline
post #13 of 15 Old 06-04-2004, 01:43 PM
MarkandPaminFL
Autozone must have a special policy for Jeepgirls that "sometimes go topless".
MarkandPaminFL is offline
post #14 of 15 Old 06-04-2004, 08:46 PM Thread Starter
new2jeep
Installed the new thermostat tonight. Temp gage now goes to about 200 and maintains. I think I finally got it fixed. I figure that the gage could be off 5 degrees since the thermostat is a 195.
Thanks everyone for the input.
Now all I have to fix is a small tranny leak. One of the hoses connecting to the radiator has a small leak. When I put the new radiator in, I replaced one of the lines but not this one. Guess I should have. I should have that fixed tomorrow.
new2jeep is offline
post #15 of 15 Old 06-04-2004, 09:20 PM
ugajeepgirl
Yeeaah, right ...
Surface temp vs. internal temp InEmberClad YJ Wrangler Technical Forum 2 01-07-2010 06:04 PM
Tachometer reading fluctuates Sambox YJ Wrangler Technical Forum 3 04-29-2009 04:36 PM
AC blowing hot--temp dial in cold, but temp dial was previously in hot greendot200200 TJ Wrangler Technical Forum 6 11-14-2008 06:26 AM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 09:01 PM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 09:41 AM
