Temeture sending unit for Guage Location -.- - JeepForum.com
post #1 of 8 Old 08-17-2011, 03:28 PM Thread Starter
PFCLinscomb
I have been looking for the Temp sending unit for the gauge inside the cab.
I have been told it on the diver side corner of the head but i cant see it.
Can someone take a picture of theirs so i can see it? I would appreciate it
-Linscomb
Times you kick yourself in your own ***: When that stupid Private wakes the whole platoon up by running through the bay screaming "Reveille,Reveille,Reveille!!!!!!!!!!!!!!!!!!! !" And your like "Who the hell put that guy on last fire guard" and then you realize.... You did -.-
PFCLinscomb is offline
post #2 of 8 Old 08-17-2011, 03:32 PM
bigbossd1030
-Linscomb
Its on the driverside near the back, it will be kinda under the fuelrail, IIRC.
I don't have any pics handy, but I thik it has one wire comming out of it, I think it is a yellow and purple one. Hope that helps.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 8 Old 08-17-2011, 03:36 PM Thread Starter
PFCLinscomb
Ill check agn, thx.
post #4 of 8 Old 08-17-2011, 03:46 PM Thread Starter
PFCLinscomb
The reason i ask i because the last owner took the ECU Tempo unit out and just left it hanging, and put the gauge sending unit in its place and just added wire to make it reach out of the wiring harness.
Here is a pic of what it looks like. If someone could draw an arrow of where it is, i would appreciate it.
post #5 of 8 Old 08-17-2011, 04:17 PM
bigbossd1030
On the otherside of this wire loom there should be a threaded hole, that is where it was supposed to go. It is on the direct other side.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #6 of 8 Old 08-17-2011, 04:26 PM Thread Starter
PFCLinscomb
I cant see a threaded hole, or one that's been plugged for that matter. Do you see it?
post #7 of 8 Old 08-17-2011, 04:33 PM
Hghgrad
Looks like it was Swapped with an obd2 motor or head.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #8 of 8 Old 08-17-2011, 04:36 PM Thread Starter
PFCLinscomb
Its still running and OBDI ECU though. Huh, that's goofy. It would makes since though. The last owner said that the motor was brand new with only 20,000 Miles on it. :P
Oil Sending unit location shansel88 YJ Wrangler Technical Forum 18 11-18-2016 12:27 PM
Sending Unit Location Kuchmeister TJ Wrangler Technical Forum 0 09-13-2009 09:21 PM
Fuel guage or sending unit??? mark12010 YJ Wrangler Technical Forum 9 06-21-2008 02:06 PM
95 2.5 oil pressure sending unit location roundedge4lfe YJ Wrangler Technical Forum 1 10-08-2007 04:37 PM
99tj Oil Sending Unit Location 2.5 chaserband TJ Wrangler Technical Forum 7 06-16-2004 09:23 PM
