Quantcast Tell Us You Restoration Story - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Tell Us You Restoration Story
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 12-16-2006, 01:59 AM   #1
89yjester
Hi there i just recently bought a 89 YJ and i'm restoring it. I thought it would be cool to hear what everyone else did in their restorations. Tell us what you did and remember photos are always welcome.
My budget is tight so i needed to bring my yj in daily driver mode first. So far i changed the distributor cap and rotor, plugs, plug wires, valve cover gasket, installed a posi-lock, fixed all of the rust, painted my fender flares and hard top, and changed all fluids. Next i will replace the seats.
Looking forward to hearing your story.
89 YJ, Chevy 350, 5.7L
Edelbrock: 600cfm 4 barrel carb, Performer series intake
Signature air cleaner, Signature Tall valve covers
FlowTech: Shorty headers, Dual Glass Pack Mufflers
My [url="http://www.rigrater.com"]RigRater[/url] Score: 545RRv1.0 with a BOA of 29.50
89yjester is offline   Reply With Quote
Old 12-16-2006, 07:14 AM   #2
jeep795
well dude, i tore my tub right off. painted the frame with por and painted the underneath with por. i replaced the windshield frame, windshield, and patched up all the rust holes. as far as engine maintence all i've done is an oil change, valve cover gasket, water pump, alternator, starter, put in a jacobs ignition system, plugs, wires, fuel pump, map sensor, oil pressure sensor. also i took out that crappy plastic looking dash and replaced it with some bent up sheet metal and just left the heater right out. just looped some hoses up in the engine compartment. i dunno i really didn't go all that extreme with restoring the jeep. the most extreme thing i probably did was buy it some nice new shoes, 33x 13.5 ltbs' mmmm here's some random pics that show some of the process. now my only words of wisdom that i can release for fear of the man is if your patching rust, weld from the bottom. take the tub right off and flip it to weld, much easier in the long run. http://community.webshots.com/user/jeep795?vhost=community&vhost=community
jeep795 is offline   Reply With Quote
Glock Forum
