Tell about this set up - JeepForum.com
post #1 of 10 Old 02-12-2002, 09:16 AM Thread Starter
Dan Morera
Dan Morera's Avatar
I got a friend who races in our local mud championship, he's a mechanic who does his own lifts, I ask the guy if could do one for me and he said yes.
Heres the deal what do you think about a 3" Susp Lift, 1" shackles and 31x10.5" in a 15x7.5" rims? He puts in the drop Pitarm and lowers the tranny and extended brake lines.
Finally I think I'm gonna be able to play nicelly in the mu.
YJ Sahara 88, 258 I6, BA/10
2.5" Susp. Lift (Aprox.), 1" Shackles 31x10.5" Cooper
Dan Morera is offline
post #2 of 10 Old 02-12-2002, 01:41 PM
bonehead99
bonehead99's Avatar
The 3" supsension lift will clear 31's fine, you may be able to get 33's with limited flex. The 3" lift and 1" shackle lift would be good if you were going with 33's
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #3 of 10 Old 02-12-2002, 03:57 PM Thread Starter
Dan Morera
Dan Morera's Avatar
Do you have pictures of your rig???? I would like to see them
post #4 of 10 Old 02-13-2002, 07:31 AM Thread Starter
Dan Morera
Dan Morera's Avatar
Does any body have pictures of this set up? Can I go 32"s with my crappy Peugot and D30 and D35 without breaking a lot of stuff everytime I drive it?
post #5 of 10 Old 02-13-2002, 08:06 AM
bob91yj
Sure you can go 32's. You may rub a little, if it becomes a real issue, bumpstop it out. I'm not a fan of shackle lifts, but an inch isn't too bad, may throw out your steering a little (caster). I'm on stock axles and go with the big boys, I just have to remember that I'm on stock axles and know my limits, usually. I snapped both rear axle shafts on a sand berm, driver error. Winched to the top of the berm, jacked up in sand, both axles out,had to pull the carrier to get the stubs out, new axles installed and moving again in an hour and a half.
Go to a 4x4 shop and buy all the used D35 axle shafts you want in most places, I get mine for $50 a set.
I certainly intend to upgrade my axles one of these days, but for now, I'll keep following Osburn as he drags those D60's over the rocks and paves the road for me. The D.I.C. is shopping for 37's now, gonna have to change my tactics.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #6 of 10 Old 02-13-2002, 08:42 AM
bobznew
I read somewhere (maybe Jeep Bible) that the D35 and D30 axles would safely fit 33x12.50's, which is what I run with no problem.
You should be able to go bigger than 31x10.50 w/ the lift+shackles.
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #7 of 10 Old 02-13-2002, 11:04 AM Thread Starter
Dan Morera
Dan Morera's Avatar
Thanks guys, I'm gonna try fit 32" if I can get some extra money. Parts are VERY expensive down here.
post #8 of 10 Old 02-14-2002, 03:34 AM
love24wheel
love24wheel's Avatar
yes you can run 32's with your puegot, and stock axles.. I did it for a very long time.. Im still running my stock axles, but now Ive got 35's.. Ive only broken one front U joint, and one rear axleshaft...
Scott
89 yj with tires and stuff like that.....
Black Jeep Member #22
love24wheel is offline
post #9 of 10 Old 02-14-2002, 07:16 AM Thread Starter
Dan Morera
Dan Morera's Avatar
Is it hard to change a U joint or an axelshaft? what tools do I need?
post #10 of 10 Old 02-16-2002, 07:40 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Do all the work yourself with the help of a friend. You'll really learn about your jeep that way and it really isn't that hard to put on a lift, or work with axle u-joints.
89'YJ w 2 1/2" suspension, 31" tires
[img]http://www.msnusers.com/_Secure/0LwAAAMAOsUcRGNwXWN5eJj7oMueGRHheRk36!Gn6B8DAiZiW5 eIyGFFvkCtTVFARKWNIth*1m1Y/Jeep1(1).jpg[/img]
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
