Tech topic: Boomerang Shackles - Page 2 - JeepForum.com
 2Likes
post #16 of 36 Old 10-09-2012, 08:33 AM
zte87
GIVE IT THE ONION
zte87's Avatar
Originally Posted by jeepster93
I am aware of the stuff I have attached to the frame crossmember. The darn thing(crosmember) almost fell off. The bumper/tire carrier is heavy and just about pulled the thing apart. So I got some reinforcements and welded and bolted them to the bumper and frame. This will effect the shackle's movement, I know this. I can hear it bang on the frame, so I know of the issue.
Also thought of cutting the military wrap from the rear springs, it has been suggested to me.
So...
What do you sugest?
I am open...to better ways. I would love more suspension movement.
I cut off the wraps on one side off all 4 springs (like the re springs) and it made a big difference in droop! I was hesitant on doing mine but am glad I did!
zte87 is offline
post #17 of 36 Old 10-09-2012, 10:52 AM
cbl600r
Where do I get some of these vac booms?
cbl600r is offline
post #18 of 36 Old 10-09-2012, 11:00 AM
sdotcarter
Pm the thread starter.
sdotcarter is offline
post #19 of 36 Old 10-09-2012, 11:08 AM
murilstone
1987 YJ Wrangler
so, what about the center bolt....what if you just leave it out?
murilstone is offline
post #20 of 36 Old 10-09-2012, 11:36 AM
fratis
fratis's Avatar
its fine to leave out.
yep trimming the wrap is important. make sure to round the ends as the sharp corners will gouge the shackle/spring hanger.
i dont particularly like bumpers that have tire carriers so id pull all that stuff off the back of your jeep. if the crossmember is bad id cut it out and weld in a new one or a piece of rectangle tubing. if you have to have that bumper remove the cross member and weld it right on the framerail.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #21 of 36 Old 01-12-2013, 11:11 PM
gfd66
I've got a shackle reversal kit on the front of my YJ. Would the Booms be beneficial for my application or only use them for the rear springs?
Genius might be the ability to say a profound thing in a simple way.
Charles Bukowski
gfd66 is offline
post #22 of 36 Old 01-12-2013, 11:34 PM
Carlos14
I have seen someone use booms on their shackle reversal however you lose most of the risk of inversion when you have the reversal. I would think just the rear would be worth it, but I can't speak from experience.
Luck Favours The Prepared
Carlos14 is offline
post #23 of 36 Old 02-22-2014, 03:10 PM
newfish1
My RH front shackle has inverted on me a few times. thankfully, the main leaf still appears to be (not) bent. I keep in touch with the previous owner; says he never experienced that. The shackles sit perfectly vertical when jeep is on flat ground. Someone recommended boomerangs for the front, but I fail to see how this would cause the angle go change without a longer main leaf.
What do you guys think?
newfish1 is offline
post #24 of 36 Old 02-22-2014, 03:22 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Originally Posted by newfish1
My RH front shackle has inverted on me a few times. thankfully, the main leaf still appears to be (not) bent. I keep in touch with the previous owner; says he never experienced that. The shackles sit perfectly vertical when jeep is on flat ground. Someone recommended boomerangs for the front, but I fail to see how this would cause the angle go change without a longer main leaf. What do you guys think?
Vertical shackles at ride height is not right.
Mail crawling.
MisfitSeven is offline
post #25 of 36 Old 02-22-2014, 07:35 PM
panaceabeachbum
great thread answered all my stupid questions without me having to ask
panaceabeachbum is offline
post #26 of 36 Old 02-22-2014, 09:56 PM
gtg413i
2003 WJ
Question: I had rubicon express springs ( non military wrap) but the main leaf snapped (not from re quality I'm sure, just from lots I über flexing and me hitting a jump too hard. I replaced with BFD springs, military wrap, but they seem to really limit flex. Since they are new, should I cut the front wrap like in a previous post, for more flex seeing thy should e less likely to break or should I leave it as is? I don't want to break another spring, or have to carry a spare, but I do want more flex. I am Soa.
Brian's Black Betty Build:
gtg413i is offline
post #27 of 36 Old 02-22-2014, 11:18 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The bolt that goes through the elbow of the shackle in the middle will hit the frame first and allow your springs to continue forward instead of flipping flat against the frame.
Anticanman is offline
post #28 of 36 Old 03-31-2015, 05:35 AM
burntoutfireguy
I'm about to get new springs, along with some M.O.R.E. 5/8" boom shackles. I noticed that they come with grade 5 greasable bolts. I wish that i could find grade 8 greasable bolts. Could someone tell me what their feelings are about grade 5 greasable bolts vs. grade 8 regular bolts?
Thanks!
89 YJ. 4.2L W/ Weber. Converted to AX15. 4" RC Lift, 1" BL, 32" Courser MXT's.
burntoutfireguy is offline
post #29 of 36 Old 03-31-2015, 06:00 AM Thread Starter
VACJ5
The shear strength between a standard grade 5 and a grade 8, 1/2" diameter bolt is roughly 3500-4000 lbs depending on what source you dig up. However, the grade 5 has a shear strength of something around 15,000 lbs. which is nothing to shake a stick at. BUT! In my opinion (what the heck ever that's worth)... the fact that they drilled a hole down the center of the bolt reduces the strength of the bolt and thus creates a failure point. Even then... I don't know many guys who shear leaf spring bolts. There is too much give in other things like the bushings, the springs themselves etc... If it were a solid mount where forces were transferred directly to the bolt, then I would worry more about shearing.
Greasable bolts are nice if you actually grease them... I ran some for a while when I was running poly bushings to keep them quiet. Then I caught the zerk fitting on a rock and sheared it off... whoops. I like rubber bushings, they may not last as long but they ride better and are quieter.
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #30 of 36 Old 03-31-2015, 08:28 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I break stuff like greasable bolts
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 01:35 PM
Boomerang Shackles with a SR kit DrifterX YJ Wrangler Technical Forum 1 02-08-2009 02:19 PM
TJ tech topic of the month never monday TJ Wrangler Technical Forum 31 12-31-2008 11:19 AM
MORE boomerang shackles xcnick38 YJ Wrangler Technical Forum 8 12-02-2008 07:00 AM
boomerang shackles rsoffar YJ Wrangler Technical Forum 0 08-21-2005 01:41 PM
