Tech HowTo: Remove Brake and Clutch assembly for repair/replacement - JeepForum.com
post #1 of 6 Old 04-19-2010, 08:12 PM Thread Starter
bharris68
Daily Driver
Okay - so I found a bunch of threads where people noted that their clutch pedals had broken off at factory welds. A lot of folks noted they had the problem, but I did not find the actual SOLUTION to remove the assembly, just that they had it fixed by a welding shop or professional welder.
So - to that end - explanation and pictures for reference. Admins/Mods - please cross-post or add to FAQ's as appropriate.
This is the Clutch Pedal assembly - the clutch removal was reasonably routine - but when Chase and I went to pressurize the system - the clutch pedal broke at the factory welds... Not fun.
To get the brake & clutch pedal out as an assembly - do the following:
1) loosen the 4 bolts on the firewall and remove them.
2) disconnect the brake pedal from the brake cylinder ram
3) slide the brake master cylinder forward until the bolts are flush with the firewall. - Top Side View
4) Up and to the left you'll find a bolt and nut holding the brake/clutch assembly to the clutch reinforcement bracket - remove it.
4.1) Pull the cotter pin holding the clutch linkage arm to the clutch pedal.
5) Right above your knees you'll find two bolts - they loosen FROM THE Dashboard side... They are just low of center in this picture:
6) everthing should be free to be pulled down now as an assembly:
Also:
You're going to spend a lot of time like this.. Get used to it.
Note that another option is to remove the long bolt between the brake and clutch so that either/both pedals can be removed.
As in this picture - the bolt in the middle is the key - if you can reach both sides AND have enough room to pull the bolt, this may be your easier solution. Note that the position
below is relatively normal and I would have been able to remove the Nut from the left and pulled the Bolt from the right. At the time I was not sure - so I pulled the entire assembly.
You'll want to pull out the shim material before you weld as it will burn off given it is made of plastic.
Installation is opposite of removal!
bharris68 is offline
post #2 of 6 Old 08-04-2012, 10:16 PM Thread Starter
bharris68
Daily Driver
Fixed Links in photos - apologies for broken links!
post #3 of 6 Old 08-04-2012, 11:11 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Thanks for the fast work/response to PM! I just linked your thread to another Jeeper who swapped in an auto for his manual and wants to get rid of the old clutch pedal.
You just gotta love this forum!
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 6 Old 03-24-2014, 05:58 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
posting just to sub for reference on the phone at junkyard
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #5 of 6 Old 12-23-2015, 06:16 PM
Opihi59
Opihi59's Avatar
Any chance you could fix your photo links again? I linked this thread to another Jeeper swapping Auto to Manual who could use it.
Opihi59 is offline
post #6 of 6 Old 12-28-2015, 03:55 PM
toyman01
1978 CJ7
^^What he said. Photos would be nice to see again.
toyman01 is offline
How do you remove the parking brake pedal assembly? veritas4156 YJ Wrangler Technical Forum 8 03-15-2010 07:42 PM
Axle Swap Tech, Question About Drum Brake Assembly Removal 01TJfuntime TJ Wrangler Technical Forum 4 01-10-2009 02:35 PM
XJ brake and clutch assembly in a TJ? jeepwrangler97 TJ Wrangler Technical Forum 1 07-20-2008 09:25 PM
Parking brake tension assembly- cheap repair DeclarationDay YJ Wrangler Technical Forum 5 12-18-2007 07:08 PM
TJ pedal assembly (brake, clutch. gas) on a CJ? apachetech TJ Wrangler Technical Forum 0 08-12-2004 06:27 PM
