Tearing YJ apart and rebuilding - Page 3 - JeepForum.com
post #31 of 282 Old 12-31-2009, 06:30 PM
Ingle47
Dont you love the pride of doing all the work you self
Keep up all the good work and keep us updated with pics
I want to see it back together
'05 Black WK Limited 4.7 /2" Daystar Poly/ rooftop tent/ cobra 29 ltb classic/ 265-75-17 Dynapro MTs/ Procomp 7" driving lights/ Saguaro switch panel/ 1.5" ws/ SuperChip/
'99 Blue WJ 4.7 / Stock
'89 YJ 4.2 /SOA/ 35-12.50-15 Tsl/ Cobra 29 LTB Classic/ XRC8/ Tube Fenders/ Side Armor/ 8.8" rear/ 1.25 WS/
Ingle47 is offline
post #32 of 282 Old 01-01-2010, 04:21 PM Thread Starter
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
Took a few hours outside today to degrease rubdown with MEK and then use metal ready and rinse. It was in the high 40's, and metal ready says it works best at 70F, so I let it stay wet with acid for about 45 minutes or so before rinsing. Prep is done and today officially starts the rebuild if you wanna get technical.
Ready for POR-15
hotelconucc93 is offline
post #33 of 282 Old 01-01-2010, 05:36 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Originally Posted by hotelconucc93 View Post
you got that 1 5/16 socket for the pitman arm? I would love to get that off. I got a puller...not a socket...
Yeah, I forgot. Will run it by tomorrow.
- Ernie
Richmond88yj is offline
post #34 of 282 Old 01-02-2010, 02:06 PM
lclark2074
lclark2074's Avatar
Did you have to sand at all or just the MEK and metal ready?
night crew 226
lclark2074 is online now
post #35 of 282 Old 01-02-2010, 03:29 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
I used a 4 1/2" grinder with 120 and 80 grit flap discs, a 3" drill bit cup wire brush (fine) and a 1" rill bit cup brush (course). I also used a random orbital with the stick on paper in 200 grit and some 60 grit. For tight exposed places and joints I used a 4 1/2 wire knot wheel.
There was not an inch that didn't get hit. Some stuborn paint stayed but it is so scratched and cut it will be fine to go over.
Some places (between frame and rear shock mount & between frame and axle bump stops) needed to be hit with a needle gun to get scale off before sanding. I also found the front grill mount totally gone and a previous pic shows where it was replaced. The body mounts for the most part are in decent shape and needed no welding, but minor scabbling with the needle. The needle also works great for old duplicolor undercoat or some similar rubberized flake paint that was on the frame. That stuff only melts and smears when you sand it with a flap disc and doesn't come off. Richmond88YJ reports he used a putty knife once before for that, but a needle gun makes it come off like a cheap suit and flake to leave a sandable surface.
POR15 says it doesn't like to go over clean paint...so it got taken off 95% and the other 5% is prepped in my mind.
After the sanding the whole frame was hit with simple green to get the black dust and first layer of any grease off, and then the MEK rub followed by metal ready. Currently it is drying in the garage after I brought it back in, as you have to hose off the metal ready & simple green.
The result is that there is a fine grey coating covering the frame of zinc phosphate and light rust....the POR 15 will love it.
post #36 of 282 Old 01-05-2010, 04:40 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Pulled calipers from the 8.8 and the D30 and painted.
Took the 8.8 outside and ground off the ford spring perches and shock mounts.
post #37 of 282 Old 01-09-2010, 05:10 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
While I wait for the recent global warming trend to pass...so I can paint the frame and not have it freeze..
I took the old tie rod and drag link and cut the boots off of the ends and cleaned them good by hand. Then I pumped grease into the fittings to press the old grease out the ball and wiped that out. The ends looked good, so I cleaned the rest of the rods up with a wire brush and ran some sand paper over them. I played around with replacement boots.
Wrapped the ends up and primed and painted.
Thinks are gonna be moving fast when the frame paint gets a burst of warm air to make things doable...I DO so hate this global warming we are having.
post #38 of 282 Old 01-12-2010, 03:00 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Frame painted with 2 coats Por15 and Chassis Coat Black uv topping. Also took some shots of the nutserts that were replaced. Getting ready to scrape and paint the D30.
post #39 of 282 Old 01-12-2010, 03:15 PM
copleydad
copleydad's Avatar
Looking Great!
I'm originally from Falls Church, moved to Boston about 12 years ago. Amazing you guys down there are having the freezing weather and we've been consistantly 10 or 20 degrees warmer.
Looking forward to see how it turns out! Miss all the good wheeling spots out around Fredericksburg down to Richmond and out by Warrenton. Not much up here.
'89 Islander 4.2l 5 speed
'14 Grand Cherokee Limited 3.6
One Jeep is Never Enough
copleydad is offline
post #40 of 282 Old 01-12-2010, 04:54 PM
Richmond88yj
Eat, Sleep, Jeep
NICE~!!!!!!
Wow! Looking Great Chet!
We need to have that as a rolling chassis by Feb 7th. Neighborhood wants us to bring all the heeps to a Chili cookoff. What better way to show off all your hard work!
- Ernie
post #41 of 282 Old 01-12-2010, 05:40 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Originally Posted by copleydad View Post
Looking Great!
LOL...I'm originally from Massachusetts! or..."Massachusettse" as the current (D) running for Teddy's seat put in her most recent attack ad, it seems spellcheck failed.
Being from Western Mass, I think if you went that way you might find something.
I intend to let ya see how it comes out for sure!
Chet
post #42 of 282 Old 01-12-2010, 05:44 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
I'll have the wife throw together the guest room for you!!! You ain't leaving till its done!!
post #43 of 282 Old 01-12-2010, 06:34 PM
jcoty
nice build!
jcoty is offline
post #44 of 282 Old 01-13-2010, 06:16 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Remember this D30? Got it from the junk yard because I needed a 4.10
Here she is now. I already showed you her drag link and tie rod.
Busy day!
post #45 of 282 Old 01-14-2010, 04:38 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Mounted 8.8 and D30 today with new RC springs and Daystar shackles....pics forthcoming...I'm too damn tired and too damn sore. Did it myself due to kids being at dentist etc etc etc
8.8 , atlas , bed liner , nv3550 , por15
Tearing into the AX-5 Rproject YJ Wrangler Technical Forum 4 12-04-2008 09:27 PM
Can you stop a top from tearing? BChamberlin TJ Wrangler Technical Forum 3 06-02-2008 10:19 AM
Tearing into the YJ tomorrow. murrayII YJ Wrangler Technical Forum 7 03-10-2007 09:41 PM
Steering box tearing my frame apart. Bobbywolf YJ Wrangler Technical Forum 19 08-25-2005 09:41 PM
