Tearing YJ apart and rebuilding - Page 11 - JeepForum.com
post #151 of 282 Old 04-09-2010, 08:17 AM Thread Starter
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
Originally Posted by Blstr88 View Post
Sorta off topic...
But what brand of epoxy did you use on your garage floor? Did it go on easy, and how is it holding up "x" amount of months later? Im looking to do mine in the next few weeks but theres so many different brands...
Used Quikcrete two part epoxy floor kit from Lowes.
Epoxy Garage Floor Coating | QUIKRETEŽ Coatings
Took 2 kits due to wide garage.
First I used two gallons of muriatic acid on the floor to strip and etch it. Two gallons diluted over about 10 applications, some straight for oil stains and thick sealed areas.
Then used kit as instructed.
Holding up great.
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
post #152 of 282 Old 04-10-2010, 02:40 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
New dash colors!
The dash cover, wheel, and associated interior all used to be this color...even the rear seat...(which will soon be black also). Here is what the old dirty color was and what it is now with Duplicolor!!!
post #153 of 282 Old 04-13-2010, 07:26 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Today...all day... fabricated the tunnel cover plate. Test fit was accomplished as seen below. After pics it was disassembled and painted. When I do the complete tub with herculiner, the top of the plate will be done and the bezels will be silver painted.
post #154 of 282 Old 04-20-2010, 09:09 AM
cvorden
1987 YJ Wrangler
Wow what an amazing build!!! One day if I ever get a garage again me and you are gonna be Chesterfield drinking buddies
cvorden is offline
post #155 of 282 Old 04-20-2010, 01:38 PM
liveanadventure
have a pro shorten it should be less then 1100 bucks ,, it has to be balanced or it will vibrate like crazy
liveanadventure is offline
post #156 of 282 Old 04-20-2010, 01:38 PM
liveanadventure
100 bucks oops
post #157 of 282 Old 04-20-2010, 05:30 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Ya, getting the driveline to a shop to take care of the front. The rear will be a Tom Woods I think.
Here are some of the lates photos.
This one shows the sway bar painted and installed with new prothane bushings. Also, have a Rough Country quick disconnect kit installed. As you can see, the power steering hoses are finally attached.
I was lucky enough to have extra asphalt material for splash guards, so I fashioned an extension kit for each side. I also have a better picture here of the disconnect kit.
I also did some neatening up of the reservoir tanks and caps. My old tank was bad, so I got a new dual washer tank and a new cap. I did some cleaning and painting of the better cap and the coolant tank too.
Also, the Smittybilt XRC8 winch and Hi-Lift came today!!!!!
post #158 of 282 Old 04-21-2010, 05:18 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
I'm ok with that....stop by the ABC....scotch and vodka fan
post #159 of 282 Old 04-21-2010, 05:20 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
argh....where is the best HiLift mounting location.....uggh...I like the hood mount and can make it easy, but I also like the rear tire carrier mount option....
Problem is I have the smitty classic rear with tire carrier...and I don't know yet what it will look like totally done and ready to go, so i am undecided. Any one have this and can elaborate?
post #160 of 282 Old 04-21-2010, 06:38 PM
cvorden
1987 YJ Wrangler
If you can help me work out all my electrical bugs I will buy you a fifth of each!!!
cvorden is offline
post #161 of 282 Old 04-21-2010, 06:45 PM
Mark4883
Very cool build, will be watching this one.
Mark4883 is offline
post #162 of 282 Old 04-21-2010, 06:56 PM
cvorden
1987 YJ Wrangler
Good Lord...
Good deal on Tom Woods shafts on Oconeeoffroad.com right now, just don't know what to select...I have to work on this tomorrow for sure...
Thanks for the tip just saved me $15 on a bikini top!!
cvorden is offline
post #163 of 282 Old 04-21-2010, 07:08 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Thanks Mark.
What do you think...shorten or get totally new front drive shaft? I cant decide!
post #164 of 282 Old 04-21-2010, 07:23 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
I counldn't take it anymore... I got a bikini thanks to Cvorden's prompting. AmericanFlag type.
post #165 of 282 Old 04-21-2010, 08:22 PM
green89yj
wow. Looks great.
Can't wait to see the Flag top too. I've had my eye on one.
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
8.8 , atlas , bed liner , nv3550 , por15
Tearing into the AX-5 Rproject YJ Wrangler Technical Forum 4 12-04-2008 08:27 PM
Can you stop a top from tearing? BChamberlin TJ Wrangler Technical Forum 3 06-02-2008 09:19 AM
Tearing into the YJ tomorrow. murrayII YJ Wrangler Technical Forum 7 03-10-2007 08:41 PM
Steering box tearing my frame apart. Bobbywolf YJ Wrangler Technical Forum 19 08-25-2005 08:41 PM
