Team Rush Weird Wiring ???? - JeepForum.com
post #1 of 4 Old 03-08-2009, 05:02 PM Thread Starter
ZGYJ
Hey all.
I am in the middle of doing the RUSH... and I ran into a snafu. Never used that word before, kinda fun. Anyway, cap and rotor... switched... drove it around for a couple of days and it's a big difference already, more usable power, quicker starts, more... you get the picture.
Anyway, went to do the coil switch, have all the parts and removed my old coil. I found my coil is attached with a YELLOW wire that goes to the connector with the BAT marking on it.
The other connection is a green wire with a white stripe, that goes to the other connection.
My PIGTAIL has two green wires with yellow stripes (one I've gathered is for TACH) and the other is for ground. The other wire is RED with a BLACK stripe.
SO.... what connects to what?
Yellow to GREEN? Yellow to RED? Or vice-versa?
Thanks... and help.. I have to get this buttoned up tonight!
Good Jeeping!
ZGYJ is offline
post #2 of 4 Old 03-09-2009, 10:34 PM Thread Starter
ZGYJ
Thanks Jeep Hammer for the PM reply. I didn't get your second PM, my box was full.
Everything is wired up and running nicely, I went with Accel 8mm wires cut to fit and opened the plugs up to 45. My YJ fires up easily and pulls nicely, the only thing left to do is change the advance so it keeps on pulling.
ZGYJ is offline
post #3 of 4 Old 03-10-2009, 12:07 AM
jeepdude1987
1987 YJ Wrangler
What was the wiring? I'm going to do that mod pretty soon (as in I have all the parts sitting in the Jeep right now, and just need to get-r-done) and I want to know cause I haven't seen how to do it.
1987 Wrangler YJ RED 4.2 5-speed, NP231, BFG 31x10.5R15 AT/KO on 15x8 gambler wheels.
Caution!!! Under construction!!!!!! Caution!!!
Finishing a 4.0 Cyl.head swap, Just got an AX-15 NP231J combo to replace the busted t-case and craptacular BA10/5. Adding Nutter bypass. Probably more to come before it is back as a DD!
jeepdude1987 is offline
post #4 of 4 Old 04-17-2010, 01:54 PM
Augy
Looking for this answer as well...
Augy is offline
team rush vs HEI bigorangeyj YJ Wrangler Technical Forum 6 12-19-2009 01:00 PM
HEI or Team Rush?? bjbrowder YJ Wrangler Technical Forum 17 11-19-2009 10:39 AM
Bad Idle After Team Rush CajunHiker YJ Wrangler Technical Forum 15 08-27-2009 07:03 AM
Hei or Team Rush ? Which is best ? mtidwell YJ Wrangler Technical Forum 11 10-17-2008 11:38 PM
team rush NJscott YJ Wrangler Technical Forum 2 06-10-2008 07:16 AM
