Team Rush Mod (Writeup w/ Pics} - Page 5 - JeepForum.com
post #61 of 71 Old 04-21-2010, 08:10 PM
spawnofsatan
I only gap mine once I upgrade my coil
spawnofsatan is offline
post #62 of 71 Old 04-21-2010, 08:20 PM
JOExFROMxNY
Originally Posted by YJ Rider View Post
I did this and would HIGHLY recommend replacing the vacuum advance spring as well to complete the mod. ...
Anybody know a link i can follow to do this on an '88 YJ? i searched, but couldn't find a post with the procedure.
JOExFROMxNY is offline
post #63 of 71 Old 04-22-2010, 12:21 PM
BigOrange90YJ
i found these in another Team Rush thread, i havnt personally used them.
Currently Jeepless, if you get too frustrated with yours I'll take it off your hands.
BigOrange90YJ is offline
post #64 of 71 Old 06-21-2011, 09:43 PM
OPlo
1987 YJ Wrangler
Trying to decide which wires to get. Little help please. Entered 95 YJ, 4.0 for my vehicle on the web sites.
The Belden's are still @ Napa, 7mm, only $21.49
https://www.napaonline.com/Catalog/C...+50038+2038050
Advance Auto no longer seems to carry the $30 Autolite.
Auto Zone, Advance Auto and O'rielly all recommend the 8.5mm MDS set which are $80 - $90.
http://shop.advanceautoparts.com/web..._735902661____
Are the MDS worth the extra $60?
Autozone also has an Acel, 8mm set for $54
http://www.autozone.com/autozone/par...87_92169_5933_
Any advice is appreciated. Thanks.
OPlo is offline
post #65 of 71 Old 06-23-2011, 01:19 AM
sanddrag
I'm using Motorcraft p/n WR4050 from Rock Auto. ~$26. I think they're only 7mm, but they seem to work just fine.
sanddrag is offline
post #66 of 71 Old 06-23-2011, 02:05 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Are you supposed to retune the carb after this mod? Or could it just depend on the jeep?
Michaelgoesrawr is offline
post #67 of 71 Old 06-23-2011, 12:02 PM
OPlo
1987 YJ Wrangler
In JeepHammer's thread they mention possibly having to lean-out the carb a bit. Depends on the Jeep. Timing shouldn't change.
OPlo is offline
post #68 of 71 Old 06-28-2011, 01:53 PM
OPlo
1987 YJ Wrangler
Did the mod over the weekend without the new plug wires. Should arrive today. Had to crimp the old plugs so they would fit tight over the posts on the new cap.
Took out my existing plugs (which looked plenty clean), gapped them out to 45 and put them back in. Anybody see a problem with this?
Also resolved a vacuum leak around my intake manifold - this has made the biggest difference so far.
OPlo is offline
post #69 of 71 Old 07-28-2011, 09:32 PM
INKUBUS
Resistor
Where is the coil resistor??
its necesary??
regards
INKUBUS is offline
post #70 of 71 Old 07-28-2011, 10:41 PM
Alabamaranger
I did the team rush plus went with the MSD Box and eliminated the duraspark box. If you thought the team rush was bad, the MSD could make you wet yourself if you got zapped.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
post #71 of 71 Old 04-09-2014, 03:27 PM
mgkbull
1987 YJ Wrangler
Can you please repost the pictures? The links to them have gone bad.
Here in New Mexico, we don't go mudding, we go dusting!
mgkbull is offline
team rush vs HEI bigorangeyj YJ Wrangler Technical Forum 6 12-19-2009 01:00 PM
HEI or Team Rush?? bjbrowder YJ Wrangler Technical Forum 17 11-19-2009 10:39 AM
Bad Idle After Team Rush CajunHiker YJ Wrangler Technical Forum 15 08-27-2009 07:03 AM
Hei or Team Rush ? Which is best ? mtidwell YJ Wrangler Technical Forum 11 10-17-2008 11:38 PM
team rush NJscott YJ Wrangler Technical Forum 2 06-10-2008 07:16 AM
