Team Rush Mod (Writeup w/ Pics} - Page 4 - JeepForum.com
post #46 of 71 Old 11-07-2008, 03:15 PM
the_mork
okay I should have picked that up and didn't. I only spent a few minutes gathering the parts anyways so I'll just take them back tomorrow. I plan on keeping the 8mm wires though since my Jeep seems to run just a touch better with them.
the_mork is offline
post #47 of 71 Old 11-07-2008, 03:23 PM Thread Starter
Brandon_YJ
1987 YJ Wrangler
As sorry as I am that you wasted your time... I'm glad it came to my attentio.
I'll edit my original post to reflect tat it is only for the 4.2 engine.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #48 of 71 Old 11-10-2008, 11:46 AM
tippmann243
what is everyone gapping their plugs to when they do this mod.
i pulled some plugs to check my mixture and realized the gap is a little small 35-40 do you think we could jump the gap size to 55-60 since we have a lot more spark energy available?
89 blazer, L31/t56 28mpg.
blazer video,
1990 jeep, 4.2, 5speed.
tippmann243 is offline
post #49 of 71 Old 11-10-2008, 11:55 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
With my new coil 0.045" was perfect.
There is no need to (and you really shouldn't) gap above that.
in a (text only)
post #50 of 71 Old 11-10-2008, 12:33 PM
tippmann243
guess ill set them all at 45 and call it a day. the tinkering never stops
blazer video,
post #51 of 71 Old 01-28-2009, 09:45 PM
fireshadow
question I looked up all new parts at NAPA and the total was around $150.00 then I looked at a juice box set for $80. any advantages between doing it with the parts from NAPA over the juice box set.
fireshadow is offline
post #52 of 71 Old 01-28-2009, 10:58 PM Thread Starter
Brandon_YJ
1987 YJ Wrangler
The "Juice Box" people took the instructions written out by Jeep Hammer (a guy on the boards here) and then substituted the cheapest crap they could to get the price down.
This upgrade is about using "premium" parts, not junk.
The Juicebox kit will work, I've seen it before, but I don't trust the components.
in a (text only)
post #53 of 71 Old 01-29-2009, 10:35 PM
fireshadow
Thanks. Thats what I thought. I agree about using the best parts, and will follow through with the stuff from NAPA. I would rather do it once and do it right.
post #54 of 71 Old 02-14-2009, 04:57 PM
Danolxf
1987 YJ Wrangler
I finally did this mod today using all the best Napa parts. Best money I have spent in ages. Had to fatten up the carb a full turn. I am now experiencing power all the way up to 4k rpm ( I let off at 4k I was skeered ) and a very smooth idle. It also started much easier than it ever had. Only thing I can compare it to was the Jacobs ignition I had on my CJ but this still beats it due to the fact that it pulls at a higher rpm.
87 YJ
RIP Mr. Whipple
Danolxf is offline
post #55 of 71 Old 04-17-2010, 02:21 PM
Augy
I have the BWD Ford E-Coil and pigtail and am wondering how to wire the pigtail. My jeep connector has a yellow and green wire (yellow connects to stock coil on side that says "BAT"). My ford pigtail has 2 green wires (-) on one side and a red (+) on the other. So which way do I splice the pigtal? Thanks!
Augy is offline
post #56 of 71 Old 04-17-2010, 03:17 PM
spawnofsatan
You have two green because one is for the tack.
spawnofsatan is offline
post #57 of 71 Old 04-17-2010, 03:18 PM
xdgt03
The yellow on the stock that says "BAT" is the +, otherwise corresponding to the red on the Ford. I'm not 100% positive on the green wires but I would think both are grounds, one to the chassis and the other to the ground side of the circuit. As long as the coil grounds well to the chassis were you mount it and you use dielectric grease on the surface then you can wire both the green wires on the Ford coil to the green on the Jeep.
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #58 of 71 Old 04-17-2010, 03:24 PM
spawnofsatan
If you ground that green wire your going to burn your coil
post #59 of 71 Old 04-17-2010, 06:56 PM
Augy
I plan to mount the coil using two "L" brackets and attach it to the inner fender. How can I wire it so I don't ruin the coil?
Augy is offline
post #60 of 71 Old 04-21-2010, 09:02 PM
JOExFROMxNY
If we are keeping our old coil, do we still gap to .045 ?
JOExFROMxNY is offline
team rush vs HEI bigorangeyj YJ Wrangler Technical Forum 6 12-19-2009 02:00 PM
HEI or Team Rush?? bjbrowder YJ Wrangler Technical Forum 17 11-19-2009 11:39 AM
Bad Idle After Team Rush CajunHiker YJ Wrangler Technical Forum 15 08-27-2009 08:03 AM
Hei or Team Rush ? Which is best ? mtidwell YJ Wrangler Technical Forum 11 10-18-2008 12:38 AM
team rush NJscott YJ Wrangler Technical Forum 2 06-10-2008 08:16 AM
