Team Rush Mod (Writeup w/ Pics} - Page 2 - JeepForum.com
post #16 of 71 Old 09-03-2008, 06:04 AM
YJ Rider
1987 YJ Wrangler
I did this and would HIGHLY recommend replacing the vacuum adance spring as well to complete the mod. This will allow you to gain more pedal in the higher RPM's. Before I could not get it to come close to red line and now I have plenty of power throught more of the pedal. Plus the part is only $5.
Live in your world, play in ours...
YJ Rider is offline
post #17 of 71 Old 09-03-2008, 06:24 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Added to the FAQ write-up list....
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #18 of 71 Old 09-03-2008, 09:48 AM
CheapSunglasses
2007 XK Commander
Thanks for a new reason to spend more money
Two quick questions....
What application did you use for the wires (ie: Ford, Chrysler, etc.)?
How did the coil wires from the harness color code to the new plug?
Thanks again....Seriously!
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #19 of 71 Old 09-03-2008, 10:32 AM
tippmann243
the wires i used were for a 94ish cheroke with a 4.0
and on the coil side of the wiring
the ford pigtail i have has red and yellow wires
the jeep end is yellow and green
yellow to yellow and then red to green.
89 blazer, L31/t56 28mpg.
blazer video,
1990 jeep, 4.2, 5speed.
tippmann243 is offline
post #20 of 71 Old 09-03-2008, 10:45 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Ahhh, my old thread has been necroposted.
Anyone interested in doing this, and why they should do this, should read this post by JeepHammer. He is the guy who invented the whole thing:
http://jeepforum.com/forum/showpost....56&postcount=5
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #21 of 71 Old 09-03-2008, 01:06 PM
bradyman1
Thanks for the help Brandon_YJ. I am going to try to do this mod soon!
Jason
Originally Posted by BLS33 View Post
I find that my hobby of strangling people to death really collides with my hobby of not being in prison.
Originally Posted by duayne77 View Post
I beat my dog every chance I can get, and you know what, I enjoy it.
bradyman1 is offline
post #22 of 71 Old 09-06-2008, 05:16 PM
Danolxf
1987 YJ Wrangler
Anyone have a list of part numbers needed for this? I have been searching and can't seem to find it.
87 YJ
RIP Mr. Whipple
Danolxf is offline
post #23 of 71 Old 09-06-2008, 05:22 PM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Not of part numbers, but I asked for parts by name from the two auto suppliers and they brought me just what I wanted/needed.
Belden spark plug wires for a 1995 YJ with 4.0.
Ford E-Coil from a 1987 Ford F150 with 300 CID inline-6.
Wiring pigtail for the coil.
Distributor rotor, cap, and cap adapter from an 82 Ford F150 with 300 CID I6.
Champion copper core spark plugs from an AMC 258.
Then have them verify that the cap is a "premuim" cap with solid brass terminals and not just copper coated aluminum. If in doubt, just get the most expensive cap they have.
That's how I did it, and am VERY happy with the purchase.
in a (text only)
post #24 of 71 Old 09-06-2008, 05:49 PM
Danolxf
1987 YJ Wrangler
Thanks man , this is my next project. I was going to run a Jacobs ignition like the one I have on my CJ but when I saw this I just had to give it a try.
87 YJ
RIP Mr. Whipple
Danolxf is offline
post #25 of 71 Old 09-06-2008, 05:56 PM Thread Starter
Brandon_YJ
1987 YJ Wrangler
For the price it's well worth it, especially if you can get the components at a u-pull salvage yard.
in a (text only)
post #26 of 71 Old 09-06-2008, 07:16 PM
bradyman1
These are the parts I used. This is utilizing the stock coil. Everything fit well.
Advance Auto Part Numbers shown simply because I have these handy...
Distributor Cap Adapter, p/n C193 AP or FR109, $5.
Distributor Cap, Standard/Blue Streak p/n KCR-202X, $20
Rotor, Comes with premium cap replacements.
Plug wires, Autolite p/n 96171, about $30
This is another part list refering to the upgraded ford coil.
If you use the E-core coil, and there is nothing wrong with using the E-core coil for this application, you just probably aren't going to get into the RPM ranges to make it really work for you...
Still, if you snag one off a late 80's or 90's fuel injected Ford vehicle where you can get the coil, coil connector and mount for about $5, then by all means, use it!
The proper plug wires for that coil would be.
Advance Auto/ Autolite p/n 96624, about $25.
If you buy an E-core coil, which is going to run about $50 or up for a good one,
You will need to buy a coil connector also, NAPA p/n ICC1, $15,
And you will have to make a bracket since there aren't any easily available in the aftermarket...
Remember, the actual "TeamRush" upgrade is just cap, rotor, plug wires...
After that, you can add and choose to do the rest in bits and pieces, tuning the distributor, adding the E-core coil, changing over to a CDI ignition module..
I took this from post 25 on here. http://www.jeepforum.com/forum/showt...=589777&page=2
Jason
post #27 of 71 Old 09-07-2008, 12:17 PM
Danolxf
1987 YJ Wrangler
Thanks again for the assist on the parts. I'll be doing the switch next weekend more likely than not.
87 YJ
RIP Mr. Whipple
Danolxf is offline
post #28 of 71 Old 09-08-2008, 12:44 AM
Bubba Ray
Nice post Brandon YJ.
Bubba Ray is offline
post #29 of 71 Old 09-13-2008, 08:41 AM
88TNSahara
I tried to do this mod yesterday. I went to 3 different auto parts stores to gather up the parts from a '87 F150. I got them back to my garage and opened the boxes, and the coil and pigtail were the only parts that looked like the parts in this thread.
Sure enough, I took off my stock dizzy cap, and the new stuff didn't fit. I took the parts back and got a refund. To make a long story short, there is a slight bit of misinformation in this thread. The parts from a '87 F150 won't work at all, which is what's listed in this thread. I clicked on the link and read the original instructions by TeamRush, and they say to use the parts from a '82 F150. If you look at any online pics of stuff from a '82, they look exactly like the stuff pictured in this write-up.
Awesome write-up though, and I will be doing this today! (with the correct parts!)
88TNSahara is offline
post #30 of 71 Old 09-13-2008, 09:20 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Thanks for pointing that out, and sorry for causing you to make a second trip.
I think that since I own an 87 YJ that I said that was the year of the Ford that the parts came from.
I'll edit the post I made to reflect this change.
in a (text only)
team rush vs HEI bigorangeyj YJ Wrangler Technical Forum 6 12-19-2009 01:00 PM
HEI or Team Rush?? bjbrowder YJ Wrangler Technical Forum 17 11-19-2009 10:39 AM
Bad Idle After Team Rush CajunHiker YJ Wrangler Technical Forum 15 08-27-2009 07:03 AM
Hei or Team Rush ? Which is best ? mtidwell YJ Wrangler Technical Forum 11 10-17-2008 11:38 PM
team rush NJscott YJ Wrangler Technical Forum 2 06-10-2008 07:16 AM
