team rush - JeepForum.com
post #1 of 3 Old 05-24-2008, 10:45 AM Thread Starter
NJscott
team rush
I read a lot of the threads on this and decided to do it. ive got everything except the new coil and wont be able to get it till next weekend. Can I replace everything else and run it on the old coil till next weekend?
90 islander ( de-stickered)
webber 32/34
ford dist. cap & rotor
daystar 1" bl
1.25" booms
NJscott is offline
post #2 of 3 Old 05-24-2008, 11:54 AM
yellow2kgt
Yes, Your factory coil will work fine. The only issue I could possibly see is the coil wire may not fit properly(the ford cap has studs instead of holes.) That's easy enough to try before you install it.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #3 of 3 Old 06-10-2008, 07:16 AM Thread Starter
NJscott
so i did it last night... a little too early to notice any improvements but two of the six plugs were grimed up all the way through the gap she had to have been running on only four. this morning was the easiest start up ever and ill bet she hasnt ran this good since 1990.
webber 32/34
daystar 1" bl
1.25" booms
NJscott is offline
team rush vs HEI bigorangeyj YJ Wrangler Technical Forum 6 12-19-2009 01:00 PM
Team Rush and gas mileage..? fishmanwill YJ Wrangler Technical Forum 4 12-17-2009 07:48 PM
HEI or Team Rush?? bjbrowder YJ Wrangler Technical Forum 17 11-19-2009 10:39 AM
Team Rush Up Grade yjmikea YJ Wrangler Technical Forum 2 01-07-2009 07:38 PM
Hei or Team Rush ? Which is best ? mtidwell YJ Wrangler Technical Forum 11 10-17-2008 11:38 PM
