Team roush upgrade questions? - JeepForum.com
post #1 of 3 Old 02-14-2013, 07:06 PM Thread Starter
rtillery34
1987 YJ Wrangler
After doing the team roush upgrade is it recommended to:
1) add its own independent ground wire from the icm?
2) gap the spark plugs to .045?
3) what should the timing be set at?
I haven't done the nutter bypass yet just the roush upgrade.
rtillery34 is offline
post #2 of 3 Old 02-15-2013, 08:21 AM
Que89YJ
The ICM and disributor need to be grounded.
Yes on the plug gap
Team Rush timing is at 8 BTDC
Que89YJ is offline
post #3 of 3 Old 02-15-2013, 11:29 AM
Old4X
1990 CJ7
You need to do the nutter if you set timing to 8 BTDC, otherwise you have to time as per factory specs, @ 1600 RPM etc and use the figures published in the factory manual.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
