TC Drop Kit ??? - JeepForum.com
post #1 of 5 Old 06-04-2011, 09:58 PM Thread Starter
CreOli
TC Drop Kit ???
hello everyone quick question. i got a 4in pro-comp lift with the tc drop kit and some 33in tires when i go wheelin to lefthand canyon the only part i scrape on is the tc skid pan. My question is do i need the tc drop brackets with 4in of lift or can i get by without it so it will stop scrapin. i know i might get some vibes in the drive train but until i can get a sye will this work?
CreOli is offline
post #2 of 5 Old 06-05-2011, 02:40 AM
CALUfootball64
you will eat u joints pretty fast and the vibes will get annoying just as quick
other then that its not that bad, just the vibes are gonna make you angry after a very short time IMO keep the drop for now
94' yj, 8.8 LSD, 4" + 1.25 shackles on 32x11.5's
95 YJ new 2.5, rust free, rhino lined, leather bucket seats, DD
14 limited Grand Cherokee Eco diesel. The "wife's car"
CALUfootball64 is offline
post #3 of 5 Old 06-05-2011, 07:24 AM
hesserdude07
only real way to know for sure, is the take the drop out and drive it. if you get no vibs and such, then run it. But a SYE can be bought pretty cheap anymore, and you can shorten a cherokee front shaft for your rear CV...
JB conversions SYE shipped is less than $200, and my cherokee shaft shortened and balanced was $60, plus U joints i supplied.
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #4 of 5 Old 06-05-2011, 10:56 AM
MLJeeper
MLJeeper's Avatar
There are ways around the TC drop. I ran a 1 " motor mount lift and increased the angle of the wedges on the spring perches. 8 degs i believe. I was able to get rid of the tc case drop at this point and YES, 1 inch can make a big difference when your climbing over stuff. If you decide to try this i sill have those 8 deg steel shims in the basement. let me know.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 5 Old 06-05-2011, 01:35 PM
TheNewbie
+1
A 1" MML will help.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
Transfer Case Drop Question...To drop or not to drop? dswi YJ Wrangler Technical Forum 11 07-24-2009 02:33 PM
Transfer case drop or skid plate drop? JIME TJ Wrangler Technical Forum 2 04-08-2009 06:10 PM
looking for drop pitman arm with more drop than typical 4" DPA swa240z YJ Wrangler Technical Forum 3 04-18-2008 12:35 PM
T-case drop and drop pitman arm??? snakester14 TJ Wrangler Technical Forum 18 08-30-2007 06:40 AM
T-Case Linkage Pivot Drop Bracket Nessisary for 2.25"BB W/ TCase Drop jbpdog TJ Wrangler Technical Forum 1 06-27-2006 07:16 AM
