tc drop??? - Page 2 - JeepForum.com
post #16 of 36 Old 12-15-2011, 04:42 PM Thread Starter
BIGJoe29
ok so the tc drop is on its way and im getting the seal the outer seal for the rear driveshaft, where it meets the transfer case, tomorrow. and i got the automatic transmission fluid my manual recommended, did i get the right stuff? its the castrol dex/merc, domestic multi-vehicle automatic transmission fluid engineered to extend tranny life. for older ford and domestic general motors vehicles
im going to install the tc drop, replace the seal and then top off the fluid.
is that the right order?
and im not really wat to do when it comes to removing the driveshaft, replacing the seal and putting the driveshaft back. are there torque specs to be met?
2.5L w/ AX-5, NP231J w/ Rugged Ridge SYE and XJ front driveshaft, open D30 and D35 w/ 4.10 ratio, stock JK 18in wheels w/ Spydertrax 1.25in spacers and 32in toyo at, 2.5in RC lift with .5in shackles(BESRK), rear TJ flares. 8.8 rebuild soon
BIGJoe29 is offline
post #17 of 36 Old 12-15-2011, 06:31 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Seal, fluid, then drop.
I used atf +4 in my tcase. I don't know about torque settings either. Sorry.
Michaelgoesrawr is offline
post #18 of 36 Old 12-15-2011, 06:40 PM
mrmud4x4
Go to the the first post in this thread.....Max did a good little write up.
http://www.jeepforum.com/forum/f12/b...78/index2.html
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #19 of 36 Old 12-21-2011, 10:35 PM Thread Starter
BIGJoe29
ok i will have all the parts on friday and i will be hoping to start working during the weekend. will post updates and questions when needed
BIGJoe29 is offline
post #20 of 36 Old 12-22-2011, 06:14 AM
MLJeeper
MLJeeper's Avatar
The seal is probably leaking because the bearing in the tail cone is worn.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #21 of 36 Old 12-22-2011, 06:34 PM Thread Starter
BIGJoe29
i got the new bearing today from a local jeep dealership because autozone didnt carry it
BIGJoe29 is offline
post #22 of 36 Old 12-25-2011, 12:46 AM Thread Starter
BIGJoe29
got the seal, bushing, tcase drop and steering stabilizer installed. also topped off the transfer case fluid. when i shift into 2nd and 4th gear my stick shifts all the way but hits the console when it is fully in. would a new console solve this(i really dont want to spend money on that)
BIGJoe29 is offline
post #23 of 36 Old 12-25-2011, 10:32 AM
MLJeeper
MLJeeper's Avatar
Pull shifter out, Place in vice, Apply heat from torch, Bend a little just below the area where it is contacting, replace, repeat if necessary.
MLJeeper is offline
post #24 of 36 Old 12-25-2011, 01:00 PM
firesoutmatt
Or just leave it in and apply heat and bend it where you like it.
firesoutmatt is offline
post #25 of 36 Old 12-25-2011, 02:29 PM
jode
Looked at your images again...not sure, but it almost looks like there were axle shims installed with the new springs? The rear diff looks like it is pointed directly at the t-case.
Can you either clarify if you installed shims with the springs, or post up a better picture of the point where the springs sit under the axle?
Hung like Einstein and smart as a horse...
90 YJ, 2.5L, 5-speed
jode is offline
post #26 of 36 Old 12-25-2011, 03:29 PM
jojojeep1
i used a stack of washers ,sprayed them black and called it good, its cheap and it keeps a nice opening between the frame and the skid plate so you can put a hose in there and clean it all out after muding.
jojojeep1 is offline
post #27 of 36 Old 12-25-2011, 03:49 PM
jode
jode is offline
post #28 of 36 Old 12-25-2011, 05:57 PM Thread Starter
BIGJoe29
i didnt put any shims there unless my RC kit came with some, which im pretty sure it didnt. thanks for the shifter help too. i'll take another pic of the rear axle tomorrow
BIGJoe29 is offline
post #29 of 36 Old 12-26-2011, 11:56 AM Thread Starter
BIGJoe29
the vibration is 90% gone so im not worried about that anymore. im going to take my track bars off because they dont let my springs articulate at all. do i just unbolt them? is there anything else to taking them off?
BIGJoe29 is offline
post #30 of 36 Old 12-26-2011, 12:55 PM
dillonjm
2013 WK
Just unbolt em.
May need to soak them in some penetrant if they are rusted up.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
driveshaft , jeep , transfer case drop , vibration
Transfer Case Drop Question...To drop or not to drop? dswi YJ Wrangler Technical Forum 11 07-24-2009 02:33 PM
Transfer case drop or skid plate drop? JIME TJ Wrangler Technical Forum 2 04-08-2009 06:10 PM
looking for drop pitman arm with more drop than typical 4" DPA swa240z YJ Wrangler Technical Forum 3 04-18-2008 12:35 PM
To drop or not to drop transfer case SkyLand TJ Wrangler Technical Forum 22 10-13-2007 01:43 AM
T-Case Linkage Pivot Drop Bracket Nessisary for 2.25"BB W/ TCase Drop jbpdog TJ Wrangler Technical Forum 1 06-27-2006 07:16 AM
