-   -   tbi wiring clean up help (http://www.jeepforum.com/forum/f12/tbi-wiring-clean-up-help-1540921/)
anthonywrangler 06-24-2013 06:59 PM
I need help identifying some wires. Im in the process of cleaning up my stock wire harness. Im left with a few wires that i dont know where they go to. These wires are going to the harness on the driver side fire wall. The colors are
Orange/yellow trace
Green (not the one that goes to the oil pressure sending unit)
Green/white trace
Brown/white trace
Light green (not the one that goes to the oil pressure sending unit)
Pink
Yellow
Brown
All these wire goes to the left side plug on the driver side firewall.
anthonywrangler 06-25-2013 05:05 PM
Bump
laybackman 06-25-2013 07:32 PM
#1 fill out your profile and add the following to your question. None of us know what year/engine /tranny YJ you are talking about.
Reason? Often they change the colors of the wires in their harnesses.
Maybe someone can help you then. :)
anthonywrangler 06-25-2013 08:31 PM
Its a 88 4.2l 258 5 spd transmission
AmmitOsiris 06-25-2013 09:13 PM
You do not have a tbi then it's a carter carb unless its not stock
anthonywrangler 06-26-2013 07:17 AM
I pulled the carburator. Its in the process of a tbi conversion. While doing the conversion I was cleaning out the stock wire harness to eliminate all the wires I don't need that was connected to the stock ecu. I was left with these wires clipped and don't know if they are important or not!?
timatoe 06-26-2013 12:05 PM
EVERY wire that goes through the firewall to the stock ECM can be eliminated. Have you thought about going to the Howell web site and reading their install instructions? That's likely going to be a better source than a bunch of guys guessing what you've got going on.
anthonywrangler 06-26-2013 02:21 PM
The Howell installation instruction doesn't tell you how to eliminate the wires. These wire are going to the conector on the driverside firewall.
laybackman 06-26-2013 02:41 PM
Are these the wires you are talking about? I think they all go Bye- Bye since they all go to the ECM which you aren't using anymore.http://home.comcast.net/~laybackman/...ixignition.JPG
anthonywrangler 06-26-2013 03:01 PM
To be honest I don't think so. The wires I mention all go to the left side of the bulkhead on the driverside firewall.
laybackman 06-26-2013 04:56 PM
Which plug is it??
http://home.comcast.net/~laybackman/8788YJPLUGS.JPG
greyarea 06-26-2013 05:16 PM
Here is my write up with all ecu pin outs and wiring colors.
http://www.jeepforum.com/forum/f12/j...16/?highlight=
anthonywrangler 06-26-2013 08:43 PM
Originally Posted by laybackman (Post 15611114)
Which plug is it??
Its the one that says dash panel!
laybackman 06-27-2013 06:24 AM
Use this picture and greyarea's information in this posting:
http://www.jeepforum.com/forum/f12/j...te-up-1066016/
check his second posting which lists the wiring going through C100 and you should be good to go!
http://home.comcast.net/~laybackman/...hpanelplug.jpg
anthonywrangler 06-30-2013 05:00 PM
Ok I got it figured out guys. Thanks very much. From the bulkhead at the firewall
1) Orange...........................ignition
2) Green/white tracer.........tach
3) Yellow.............................ignition switch
4) Pink.................................under hood lamp
5) Green...............................starter relay
6) Light green.......................a/c couch
7) Brown..............................fuse diode
All I need out of these seven wires is only 1, 2, 3, 5. Now my new question is, in my tbi swap I'm using the ford tfi coil with a 8 pin module, and a converted stock distributor. How do I wire these four wires for my setup?
The time now is 07:09 AM.
