TBI vs. Quadrajet - JeepForum.com
post #1 of 21 Old 02-13-2014, 07:04 PM Thread Starter
treefiddyYJ
TBI vs. Quadrajet
I'm looking for some opinions/experiences. I put a chevy 350 in my 95 YJ a few years ago, and I've been running it with an Edelbrock 600 carb. It runs like ***** on the slightest incline so it's time to replace something.
My options are to buy a rebuilt Qjet and adapt it to my square bore intake or put a tbi system on the engine.
The price difference would only be $100-$200 (with the tbi setup being more expensive).
The Qjet would basically be a swap and go (with a little tuning).
If I put tbi on it I would buy a pulled motor along with the wiring and computer and swap everything onto my 350.
I still have the original electric fuel pump in my Jeep which is currently regulated down for the carb so that wouldn't be an issue. However, I would have to swap in some sensors and such so it would be a bit more work than installing a Qjet.
Is the tbi setup worth the extra work?
treefiddyYJ is offline
post #2 of 21 Old 02-13-2014, 08:03 PM
aviationofficer
1987 YJ Wrangler
I recommend the Quadrajet. Some people say the Quadrajet is a bad carburettor buts its really not. Just by a good rebuild kit. I also recommend buying a manual on how to rebuild and modify the Quadrajet. They run from about $10 to $20 on ebay. If you rebuild and tune it right, it will be a great carburettor and your 350 will run great!
aviationofficer is offline
post #3 of 21 Old 02-13-2014, 08:06 PM
superj
Quadrajet is a great carb. I liked it on my old truck and swapped a holley odd to go back to one. Great off road too. But, fuel injection is a lot better. You really cannot beat it and your jeep will run upside down with it and have zero fuel related problems
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 21 Old 02-13-2014, 08:08 PM
superj
But, I would run the qjet just because I get tired of wiring and hate messing with that type of stuff
superj is offline
post #5 of 21 Old 02-13-2014, 08:18 PM
YJRyan
I am new here but all my previous mechanical experience is with GM's. The Q-Jet is a great carb when tuned correctly. If you go that route just make sure to clean well and get the correct rebuild kit. The Q-jet manuals have lots of good tips and tricks. You may still have the problems with inclines as the Edelbrock design is similar to the Q-jet.
If you are not afraid of the wiring and extra work the TBI would be better off road. Make sure your donor setups intake will fit the heads you have also.
YJRyan is offline
post #6 of 21 Old 02-13-2014, 10:14 PM
plym49
There is a better carb than the Quadrajet and that is the earlier Rochester 4 Jet carb. It is square bore, equal primary and secondaries and completely mechanical. It was used on lmid-fifties to early-sixties Chevys, Cadillacs, Oldsmobiles, etc. You will get more torque and economy out of this carb and it will not bog down like a Quadrajet can when the big secondaries open. Quadrajets are good for raw power, 4 Jets are good for drining finesse and that is what you need off-road.
plym49 is offline
post #7 of 21 Old 02-14-2014, 07:06 AM
roadyrob
1987 YJ Wrangler
as your biggest complaint is problems on inclines I'd go with the tbi. I'm a carb guy and luv my holley but this is the one area where FI is by far the best.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #8 of 21 Old 02-14-2014, 07:26 AM
bgredjeep
1987 YJ Wrangler
Do you prefer night or day? That's what you are comparing. If you wheel, EFI hands down.
End of story
bgredjeep is offline
post #9 of 21 Old 02-14-2014, 08:01 AM
mrdeath2000
EFI. period.
The whole reason you created this thread is because the carb cant hang on a minor incline... so what happens when you try a bigger incline with a better carb? annnnnnnnd die.
Would you bore and stroke a 2.5L? or pickup a 4.0/v8 ?
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #10 of 21 Old 02-14-2014, 04:31 PM
brianandcara
1987 YJ Wrangler
EFI is great if know basic wiring and can follow a logic diagram. Ranch I used to work for was in the sierra foothills on some steep terrain, they had a fleet of old chevy's I maintained all with the 350 and qjet and never had a problem with them once you get them properly tuned in. I just swapped a 4.0 into my 87 and love the cold morning starts right away aspect.
brianandcara is offline
post #11 of 21 Old 02-14-2014, 08:07 PM
Old4X
1990 CJ7
Qjet. Simplicity beats complexity every time.
It is popular enough that spares are all but free, and tons of tuning instructions and tips and tricks on the net.
Large fuel bowl is not as sensitive to incline issues as the smaller carbs.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #12 of 21 Old 02-14-2014, 09:46 PM
bgredjeep
1987 YJ Wrangler
Except at an angle.
I ran a weber for years on my Jeep. It was great, cranked right up, ran well at angles offroad. Swapped to Howell efi and it is better in every way.
post #13 of 21 Old 02-15-2014, 08:22 AM
Old4X
1990 CJ7
Originally Posted by bgredjeep View Post
Except at an angle.
Can you replace your entire fuel system for under $75? I can.
And this whole "won't run on inclines" is mostly bull. 99.99% of the Jeeps never see or experience such conditions. Of Those that do, they end up needing extensive body work to repair roll over damage. BTDT
Old4X is offline
post #14 of 21 Old 02-15-2014, 08:27 AM
mrdeath2000
That's not the problem though. His carb works great, until he encounters am incline. If he was mudding/sanding I'd aagree. But if he's rock crawling and on an incline for any decent amount of time, or working different lines, his **** will stall.
Sorry guys can't go with you my carb can't handle that trail... Don't worry you can ride in my 2.5l.
post #15 of 21 Old 02-15-2014, 08:32 PM
tiptoptune
whatever gets you wheelin quickest. Qjet and adapter - hood clearance?
tiptoptune is offline
