Unfortunately the above is pretty much correct. It's kinda like puttin Cool Whip on a turd. Kinda looks like a sundae, but I still wouldn't eat it......not even with sprinkles.
Throwing money into a 2.5L is a .......Its a common mantra from most peple here. The fact is that the TBI and the MPFI were only about 10 HP difference at best. That being said the fact the MPFI has diagnostics and the fuse layout gets rid of the links is a big advantage if you're going to keep it and if in the future you want to put the 4.0L in it then you only need to add the 2 injector wires to it to make the wiring harness ready for the new motor.
I did it in mine because I didn't have the money for a complete drive train swap for the 4.3 at the time. You do need to change the fuel pump, I removed the in tank one and put one on the frame rail. Hardest part of the swap is figuring out the wiring but once that's done your good to go. I find it starts better and runs smoother than the TBI 2.5, power is not much more but the throttle response is instant. Was worth it to me esp since the motor I got has no leaks at all
I do hate how everyone puts down the 2.5. I've wheeled with guys and had them ask me how I like the 6 halfway through the day...I tell them I wouldn't know, I've only got the four. Nobody believes it goes and does as good as it does with only a 2.5
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
