TBI 4.2 running rich? - JeepForum.com
post #1 of 4 Old 03-12-2011, 04:55 PM Thread Starter
renowrangler
So I bought this 1990 about a month ago. The PO said it has about 500 miles on this rebuild motor which is when he injected it. It passed smog immediately however since then it has had some problems.
Some pretty potent exhaust fumes in the cab getting much worse (partly due to not having a tailgate bar for my soft top), however it also hesitates at low RPM and misses sometimes at idle.
I know this could be caused by one or several issues and my research so far points to electrical issues. What is throwing me off is that I am obviously not too mechanically inclined and I dont know a whole lot about throttle body injection and what could be causing this.
Any help would be greatly appreciated.
2000 TJ, 4.0, Locked, 4.88's, 35" XTerrains, Warn M8000, Custom this, that and the other.
renowrangler is offline
post #2 of 4 Old 01-19-2012, 08:05 PM
Sybenn
fixed????
Did you ever find any info on this problem? I have the TBI from an Astro van installed on my 4.2 YJ and its running rich too
Sybenn is offline
post #3 of 4 Old 01-19-2012, 10:45 PM
NonRubicon
Possible cause of running rich with the TBI:
-bad O2 sensor
-intake/vacuum leak
To start I'd check for any vacuum leaks at the TB gaskets/adapter and at the intake manifold.
Also, check for any codes.
NonRubicon is offline
post #4 of 4 Old 01-20-2012, 09:04 AM
Berniebikes
-bad O2 sensor
-intake/vacuum leak
What he said! to check for codes put a jumper wire between the A and B terminal of the ALDL connector, turn your ignition to on and count the flashes on your 'check engine light'. Report back here what you find out.
Berniebikes is offline
running rich guy.griffin YJ Wrangler Technical Forum 9 12-20-2010 11:56 AM
running rich bamacj YJ Wrangler Technical Forum 5 01-16-2007 02:34 PM
2.5 running rich KOTA YJ Wrangler Technical Forum 0 08-13-2006 10:11 PM
Still Running Rich - What else could it be? Sabreman YJ Wrangler Technical Forum 21 06-08-2006 10:13 PM
94 running rich pezley69 YJ Wrangler Technical Forum 6 05-23-2006 07:46 PM
