Taurus fan question - JeepForum.com
post #1 of 4 Old 04-18-2010, 07:54 AM Thread Starter
MWguy101
Taurus fan question
I just found a Taurus fan from a 3.0 at the junk yard. I could not find a 3.8l. Is that a good fan? I did find a dual fan from a windstar that was a 3.8l. Should I have gotten that one?
95 YJ, 4" RC lift, 33x12.50x15 Durtrac
MWguy101 is offline
post #2 of 4 Old 04-18-2010, 02:08 PM
Que89YJ
The reason for the Tarus fan is the dimensions as well as the amount of air it moves. If its a good fit for the radiator then it should work.
Que89YJ is online now
post #3 of 4 Old 04-18-2010, 03:15 PM
Fhajad
Don't think the 3.0L is the same size.
The 3.8 is the perfet choice because it mounts in perfectly with no fabrication.
Fhajad is offline
post #4 of 4 Old 04-18-2010, 03:25 PM
bigsquat
its hard to believe you couldnt find a 3.8 taurus in the junk yard! around here there piling up. those 3.8's have aluminum heads that pop head gaskets like crazy. and there trannys are just as bad. hell i hve one in my driveway
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
Taurus fan wiring question czjeeper YJ Wrangler Technical Forum 10 06-17-2009 09:49 PM
taurus fan up grade question mtn_wrangler YJ Wrangler Technical Forum 6 12-08-2008 09:42 PM
Taurus 2 speed fan question, mainly what to do about coolant overflow reservoir subzeroedj TJ Wrangler Technical Forum 11 07-21-2008 08:13 PM
Mark VII/Taurus Install Question Jeebs YJ Wrangler Technical Forum 8 03-25-2008 06:42 PM
Question for those with Taurus fan drew2000 YJ Wrangler Technical Forum 28 06-11-2007 10:47 PM
