Taurus fan power requirements - JeepForum.com
post #1 of 19 Old 07-25-2007, 10:53 AM Thread Starter
jbolty
jbolty's Avatar
I need a new fan clutch so I decided to go with a taurus fan instead. I have read everything there is to read on this install. Got the fan and mounted it in. Tight fit between it and the water pump pulley but it fits and the shroud width is just about perfect. So far so good.
Ready to wire it up now. Just about every write up on this mod talks about the massive power draw of this fan but the fan I got came with part of the wiring harness which has two inline fuses (one for each speed) which are only 40 amps, plus the wire going to the fan motor is only 10 gauge, at most. I have some heavy wire (6 and 8) laying around so I could use that but that seems like overkill for such a short run and a bending connecting headache. The distance from the fan to the relay is only about a foot so it seems like sticking with #10 wire should be fine. Or maybe #8 from the power source to the relay then #10 from there?
What is the general consensus on this part of the install? Many of the write ups seem to use fairly small wire but I used a couple of pieces of #16 just to test the fan and it got pretty hot pretty quick.
While we are talking about this; what is the consensus on a fan controller? There are tons out there but for some reason the ones that go into the radiator fins seem like a bad idea to me. For now I am just planning to get it working with a manual switch to see how it performs then thinking about drilling/tapping a temp switch into the thermostat housing; those switches only cost about $10. Centech makes a controller that works with the existing temp gauge sender but it is $79.
I have not taken any pix of this and there are probably plenty already but I will after it's done if anyone is interested.
Thanks
jbolty is offline
post #2 of 19 Old 07-25-2007, 10:59 AM
TheWastedYears
I have dual electric fans on my Malibu. I use the "fin sensor" to control the fans, so I can run the fans after the engine is off.
So far... 10 yrs and no problems.
Jay™
95 Jeep Wrangler: 2.5L O' Fury
TheWastedYears is offline
post #3 of 19 Old 07-25-2007, 11:29 AM
1 ton yj
1 ton yj's Avatar
I only run the high speed. I used 8 gauge stereo wire because I had a ton of it with a maxi fuse already built in. It's powered straight from the master battery switch (made my own body harness) through a $25 100 amp 100% duty cycle snow plow soleniod from Grainger. It's grounded straight to the battery with 10 gauge. The soleniod is grounded by my ECM but Painless makes thermostatic switches for about $12 you thread into a water jacket or thermo housing. I don't have a switch anywhere in the system, I let my computer do the thinking for me.
DO NOT use the radiator probes! I've never messed with the $$$ controllers but give it a shot if you like.
1 ton yj is offline
post #4 of 19 Old 07-25-2007, 11:44 AM
Angelous
1987 YJ Wrangler
I have the radiator probe and have had it for a while with ZERO problems. Thats what was hooked up to my thermostatic fan control module.
"There is no hole to deep, or mountain to steep, for the driver of this Jeep!"
87 YJ - 2.5 - TJ Flare Swap - Rubicon's - no track bars -
Angelous is offline
post #5 of 19 Old 07-25-2007, 01:14 PM Thread Starter
jbolty
jbolty's Avatar
Wow, two for and one against the "fin" sensor. I should have done a poll.
My thinking is that the temp of the various areas of the radiator will vary wildly, so placement would be important.
thanks for the feedback, so far.
jbolty is offline
post #6 of 19 Old 07-25-2007, 01:39 PM
1 ton yj
1 ton yj's Avatar
The fin type sensors are inacurate. Just because they work doesn't mean they work well. The thermostatic switches are cheap and so easy to install it does not make any sence to not use one.
1 ton yj is offline
post #7 of 19 Old 07-25-2007, 01:55 PM Thread Starter
jbolty
jbolty's Avatar
Thats why I'm asking. I have not examined my engine completely to determine if there is a place to screw in a sensor other than the existing location where the gauge connects, and I would like to keep the gauge. Is there another plug somewhere.
Plus, riddle me this. If I get a switch on the engine somewhere that turns on at say 200 and off at 185, in theory it would never turn off because I have a 195 thermostat so the engine temp would never get lower than that.
That's why I was thinking to put it in the water outlet, after the thermostat. That way the enging would warm up to temp and eventually the thermostat would open and send hot water to the radiator. This would trigger the switch to turn the fan on.
I also considered drilling a hole in the radiator and brazing in a bung for a sensor there. Or, I wonder if I could screw one into the drain plug?
I saw a picture on another forum of a setup with the upper radiator hose cut and re-joined with a metal tube that had a sensor switch in it.
Lastly, I have been looking around since my original post and I can't find a sensor/switch for less than about $35
I'm sure I am over thinking this but as my dad always says, "If you don't have time to do it right then you sure as hell don't have time to do it over again."
jbolty is offline
post #8 of 19 Old 07-25-2007, 07:25 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
My cheapo $17 Advance Auto "fin probe" thermostat is very accurate. I used a Fluke Heat probe to adjust it and test it. It comes on around 196 and in 13 seconds the temp was down to 144 to 142 when it shut down. Every time. Granted you have to use something to measure the temp to find out where to set it, but then it's perfect. Of course I set it up when it was about 50 outside. Now that it's 100, it takes a little longer to cool, maybe 35 seconds on low speed. But thats not the probes fault. Here's my schematic if you want it.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #9 of 19 Old 07-25-2007, 08:54 PM
1 ton yj
1 ton yj's Avatar
Why do you cool all the way down to 142? Am I reading that correctly?
1 ton yj is offline
post #10 of 19 Old 07-25-2007, 09:23 PM
Mr.B
Mr.B's Avatar
That is the temp that the Fluke probe went down to on the radiator, not the temp of the engine.
Oh and the engine temp guage never goes below 190.
Ham license:
Everyone is Welcome
Mr.B is offline
post #11 of 19 Old 07-25-2007, 11:42 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
the fuses already on the fan are probably slow blow fuses. the extreme draw you hear about with this fan is mainly only on start up where it can pull 100 amps + for a second or so. once it's moving it'll settle down to about 30-35 amps on high, which makes sense for the 40 amp fuse.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #12 of 19 Old 07-26-2007, 04:44 AM
drew2000
drew2000's Avatar
I've got a Taurus fan I'm going to install this weekend, with a DCCONTROL fan controller. I think most of the wire is 12 gauge.
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #13 of 19 Old 07-26-2007, 06:08 AM
Don-T
I am running a Taurus fan through a 30 amp blade fuse and a relay controlled by a temperature switch mounted in one of the heads on the motor. It has not blown the fuse yet. I have a DC Controls controller ordered so the fan won't have to run all the time in cooler weather.
12 Rubicon
Don-T is offline
post #14 of 19 Old 07-26-2007, 07:03 AM Thread Starter
jbolty
jbolty's Avatar
What kind of switch do you have in the head and where did you mount it? I gave a quick look around the other day and did not see an extra hole or plug into the water jacket.
The more I think about this it seems to make the most sense to measure the water temp in the radiator because if the thermostat is working correctly it will be closed until 195, then when it opens and the radiator gets a rush of hot water the fan will come on.
thanks
jbolty is offline
post #15 of 19 Old 07-26-2007, 07:43 AM
Don-T
thanks
I guess you are running the 4.2 motor. I don't recall a port to install a temperature sensor it. I have a SBC so there is a spare plug in the passenger side head. I bought a switch from Summit Racing that is supposed to close at 200* and open at 185* if I remember correctly. My thermostat is a 195*.
I have an issue with my setup because either the temperature switch is opening early, or there is much difference in temperatures in the motor. The fan starts at about 190*, the thermostat open at 195* and the temperature stays at about 195* so the fan is always running. I ordered a DC Controls controller in the hopes that I can get it set to keep the motor between 195* and 200* with the fan running at a slower speed. I will be measuring the temperature in the fins near the inlet to the radiator so the fan will not start until the thermostat opens and I hope it will regulate the fan speed to keep it as noted above.
12 Rubicon
Don-T is offline
Sye/DS requirements Exl2392 TJ Wrangler Technical Forum 1 01-12-2010 07:49 PM
3:07 to 4:56 gear requirements Existence TJ Wrangler Technical Forum 21 10-19-2009 09:15 AM
Requirements for regear ballallday89 TJ Wrangler Technical Forum 4 09-19-2008 10:20 PM
Any special SYE requirements? river rat TJ Wrangler Technical Forum 3 09-14-2005 09:49 AM
RE 4.5" Requirements? WR4NGLER TJ Wrangler Technical Forum 9 05-09-2005 12:32 PM
