Tapping Question? - JeepForum.com
post #1 of 7 Old 06-23-2002, 09:39 PM Thread Starter
Johnny'sJeepen
Tapping Question?
When I start my jeep after it has been sitting a while I hear a tapping sound coming from the engine area. After letting the jeep warm up the noise goes away. Any ideas as to what this could be? And what can be done without spending a heap of cash to fix the problem? The motor has 110k on it.
Thanks in advance
J
Johnny'sJeepen is offline
post #2 of 7 Old 06-23-2002, 09:43 PM
evilpsych
evilpsych's Avatar
just noisy lifters.. go to a higher weight oil and it should go away somewhat.. running a motor flushing solvent before your oil change will help fix this somewhat by cleaning the lifters. If you're using 5w30, try 10w30, if 10w30, try 10w40 or even 10w50. If it doesnt fix the problem, you may just have to live with it, or you can try 20w50 as a last resort. It's not anything that's gonna blow up your engine, just your engine telling you that it's getting time for a rebuild sometime down the line. I've got a 92 explorer that does it all the time. goes away when it warms up..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 7 Old 06-23-2002, 09:55 PM
UglySkunk
UglySkunk's Avatar
I had that problem in my 91YJ bout 3 years ago, I switched to castrol 20w-50 and have heard it since
91 YJ currently rebuilding
my jeep can fly can yours
if you don't know about cages or spiked tang sit down and shutup
UglySkunk is offline
post #4 of 7 Old 06-23-2002, 10:10 PM
Bob K
Bob K's Avatar
It's a Jeep thing!
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #5 of 7 Old 06-24-2002, 07:12 PM Thread Starter
Johnny'sJeepen
I do run 20w 50 now. I have been for the last two oil changes.guess it is a jeep thing, Thanks to all for the input.
Happy Jeepen
J
post #6 of 7 Old 06-24-2002, 08:14 PM
jamesrob
I had the same prob a few years back and thought it was a lifter also, but when I put headers on I found the rear header bolt broken. This lead to a leak at the manifold and when it heated up the manifold expanded and the leak went away. With 110 thousand it could be a leaky exaust gasket. Just another thing to check.
jamesrob is offline
post #7 of 7 Old 06-25-2002, 07:28 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Along with a good quality oil, make sure you also are using a good quality oil filter.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
Oil pump tapping? scoin TJ Wrangler Technical Forum 2 06-19-2009 06:19 PM
Need a Self Tapping Bolt HAARUBICON TJ Wrangler Technical Forum 3 04-06-2009 01:41 PM
leaking headgasket? / valve tapping question griffsyj YJ Wrangler Technical Forum 5 01-17-2009 04:19 PM
follow up 1/2-13 tapping claytonandson TJ Wrangler Technical Forum 14 07-13-2007 11:39 AM
Engine Tapping TWrangler TJ Wrangler Technical Forum 19 10-11-2006 07:21 PM
