Tapping/knocking from front right corner of axle? - Page 2 - JeepForum.com
post #16 of 18 Old 08-10-2011, 02:40 PM Thread Starter
jeep_maniack
Originally Posted by laredojo View Post
no video.
Works for me...
I agree it's not normal, I'm just wondering if it's normal for the whole thing to shake like that since the u-joint bearings are out. I believe the joint being out would cause that, but yes either way I will get it fixed.
Thanks guys!
..l_______
./l ,[_0_0_],
.l----L -[]lllllll[]-
()_)=o()_)=o=)_)__-_-__-__-_-___
jeep_maniack is offline
post #17 of 18 Old 08-10-2011, 05:04 PM
timatoe
timatoe's Avatar
A bad ujoint needs to be replaced but will not make the wheels fall off. The stub shaft is connected to the unit bearing by that big *** 36mm nut, the unit bearing is then bolted to the knuckle and the wheel is bolted to the unit bearing, unless there's some major unexplainable physics at work the wheel cannot fall off because of a bad ujoint. You can physically separate the ujoint and pull the inner shaft completely out and still get your rig home.
timatoe is offline
post #18 of 18 Old 08-11-2011, 08:34 AM Thread Starter
jeep_maniack
Okay good to know, thanks! I'm getting a bunch of stuff looked at today so I'll just have them look at the front u-joints as well.
Thanks everybody!
..l_______
./l ,[_0_0_],
4.0 Knocking/tapping noise - need help diagnosing rothrock TJ Wrangler Technical Forum 5 11-07-2012 01:41 PM
Two Probs, Transfer Case loud Knocking in 4wd and Changing outer axle shaft front YjShane YJ Wrangler Technical Forum 15 06-07-2012 09:09 PM
Knocking/Tapping/Clicking ATL_rob TJ Wrangler Technical Forum 13 12-28-2010 05:06 AM
cyl 2 not firing, and tapping/knocking sound mweber01 YJ Wrangler Technical Forum 1 10-18-2010 06:00 PM
Front axle has a knocking sound... any ideas? jonhodge TJ Wrangler Technical Forum 7 04-29-2010 09:14 PM
