Tapping/knocking from front right corner of axle? - JeepForum.com
post #1 of 18 Old 07-31-2011, 05:06 PM Thread Starter
jeep_maniack
Hey guys,
I have a 1989 yj wrangler, and it's kind of always had this loud clicking noise from the right front corner of the axle. Just recently the noise got louder, though, so i took the tire off and it looks like it's coming from a bearing or maybe a bushing going out. when looking towards the engine there's a really loose round piece of metal around/on the u-joint spindle thing that spins and knocks around. it looks to be like inside/towards me of the carrier but behind the u joints like right where the axle opens up. I'm out of town for a week so i can't get any pictures up right now, but i will once i get back if i need to.
Can anyone tell me what's wrong and/or which part(s) i need to replace? I believe it's a dana 44 axle which is what was oem for this model if i remember right (correct me if i'm wrong).
Thanks, i would really appreciate any input!
..l_______
./l ,[_0_0_],
.l----L -[]lllllll[]-
()_)=o()_)=o=)_)__-_-__-__-_-___
jeep_maniack is offline
post #2 of 18 Old 07-31-2011, 05:55 PM
laredojo
sounds like the axel ujoint has given up the ghost. you will need to replace it. or have it replaced. pictures would help.
formerly member yj89joe
laredojo is offline
post #3 of 18 Old 07-31-2011, 06:59 PM Thread Starter
jeep_maniack
That would make sense. I actually ended up having a chance to snap a quick picture before I have to officially leave:
It's hard to see, but it's to the right of where it's all greasy.
What do you guys think? Thanks!
..l_______
./l ,[_0_0_],
post #4 of 18 Old 07-31-2011, 07:11 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Look to the left where the internals of the u-joint have ground themselves into dust and the rusted metal dust is bright pinkish/red.
Install a new u-joint.
CJ7-Tim is offline
post #5 of 18 Old 08-01-2011, 12:37 AM
jayvando707
Yep! Thats it! Just had the same thing happen to me not too long ago... i was like "what the hell is that sound!?"
Do both sides!
It is better to be tried by 12 than to be carried out by 6....
jayvando707 is offline
post #6 of 18 Old 08-01-2011, 01:38 AM Thread Starter
jeep_maniack
Okay thanks guys! I planned on both haha.
Thanks a bunch!
..l_______
./l ,[_0_0_],
post #7 of 18 Old 08-09-2011, 01:00 PM Thread Starter
jeep_maniack
Question.. Where isn a good place to get these joints from? And how hard would it be to swap them out? I consider myself fairly mechanically inclined.
Thanks!
..l_______
./l ,[_0_0_],
post #8 of 18 Old 08-09-2011, 02:23 PM
CJ7-Tim
CJ7-Tim's Avatar
Most auto parts stores sell cheap parts and quality parts. I prefer the good stuff at NAPA for almost all my Jeep parts. The u-joints at Advanced/IdiotZone are cheap, and tend to wear out quickly. Cheap parts are cheap for a reason.
Buy, rent, or borrow a ball joint press and use that to replace the u-joint. The ball joint press is faster and easier than pounding on u-joints with a hammer and some sockets.
read the linked info –
Unit Bearing - 1
D-30 Axle Shaft Removal
U-Joint Replacement - 1
DELTA 4X4 CLUB TECHNICAL DEPARTMENT - U-JOINT REPLACEMENT
Harbor Freight U-Joint Tool
3-in-1 Ball Joint/U-Joint/C-Frame Press Service Kit
CJ7-Tim is offline
post #9 of 18 Old 08-09-2011, 02:37 PM
pasinbuy
Be very very careful. if you have to drive do not go fast and stay away from other drivers.
When your u joint goes your wheel very well may fly off.
When the front u joint breaks it may or will grind into the other side of the joint and break your wheel off of the ball joints. I have seen it happen, too often.
Most of us would prefer that you park it until you fix it. You are now taking your life and the life of others in your hands.
pasinbuy is offline
post #10 of 18 Old 08-09-2011, 03:03 PM
TheNewbie
I don't think that YJ's ever had a D44 front. There were a limited number on Candian YJ's that had a D44 rear though. The standard front axle was the D30 for all years of the YJ.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #11 of 18 Old 08-09-2011, 03:26 PM
CJ7-Tim
CJ7-Tim's Avatar
In 2wd there is no pressure on the u-joint and it will make tons of warning noise before it lets loose.
A failed u-joint causing the wheel to fall off is highly unlikely. It is more of possibility when 4x4 is engaged, but still rather unlikely.
CJ7-Tim is offline
post #12 of 18 Old 08-09-2011, 05:27 PM Thread Starter
jeep_maniack
Okay thanks guys! I appreciate all of the input! So I should still replace then joints if they aren't what are causing the clicking noise andnthey aren't what is loose? I'll get a video up of what it's doing so you can see for sure. It just seems like it's coming from the shaft being loose, not the joint bearings etc. Themselves.
Thanks!
EDIT:
So i took the tire off again and looked at it. the u-joint is loose, but would that cause the whole u-joint shaft to knock around the inside of the axle?
Thanks again!
..l_______
./l ,[_0_0_],
post #13 of 18 Old 08-09-2011, 06:22 PM Thread Starter
jeep_maniack
Okay, got the video.. Is it normal for the whole shaft to move around like that with the u-joint just being loose? i can definitely see how it would since it's done, but i just mean like should it be moving that much? it's kind of a dumb question because i'm sure that it is normal since the joint is shot, but i just want your guys' input.
http://s234.photobucket.com/albums/e...t=DSCN0309.mp4
Thanks again!
..l_______
./l ,[_0_0_],
post #14 of 18 Old 08-09-2011, 08:52 PM
laredojo
no video.
laredojo is offline
post #15 of 18 Old 08-10-2011, 07:33 AM
pasinbuy
Tim, there is lots of pressure on the front u joints, less on a stock Yj granted. If you have a solid front axle like most 4wd vehicles. Then it does not matter if you are in 4wd or not. The pressure is there on the u joint.
I understand your logic, and no offence Tim, but in this case you are wrong. I have seen it happen more than one time. When the u joint goes it meshes with the other side same as if you threw a wrench into moving gears. The mesh breaks outward and the ball joints get the force and the wheel fall off. You do not have to be in 4wd for this to happen. In 4wd it will happen very quick.
Recently a cousin of mine was talking to me on the phone while driving on the highway. He was asking me what the noise could be from his front end. (The u joint broke) anyway before we could get any further in the conversation, he dropped his phone and I listened to the result. His wheel broke away and took off down the highway. A bad front u joint is very dangerous. To be honest anything bad in the front end is dangerous.
After looking at the video. what I see is not normal at all. Please fix it ASAP.
pasinbuy is offline
4.0 Knocking/tapping noise - need help diagnosing rothrock TJ Wrangler Technical Forum 5 11-07-2012 01:41 PM
Two Probs, Transfer Case loud Knocking in 4wd and Changing outer axle shaft front YjShane YJ Wrangler Technical Forum 15 06-07-2012 09:09 PM
Knocking/Tapping/Clicking ATL_rob TJ Wrangler Technical Forum 13 12-28-2010 05:06 AM
cyl 2 not firing, and tapping/knocking sound mweber01 YJ Wrangler Technical Forum 1 10-18-2010 06:00 PM
Front axle has a knocking sound... any ideas? jonhodge TJ Wrangler Technical Forum 7 04-29-2010 09:14 PM
