#1 | ||
A tale of two starters
#2 |
check your connections and grounds. replace your battery terminal connector things. mine did this when i first got it. i cleaned it all up and made sure all the contacts were good, haven't had a problem yet (except for when the starter seized and i had to get a new one, but that's unrelated)
#3 | |||
Jello Puddin'
Mine was doing this about a month ago and it turned out to be some light corrosion between the terminal and the cable clamps.
DO NOT BUY ANYTHING FROM OffroadToyStore.com Quote:
#4 |
Still no luck
I read your post. I removed both the ground wire and the postive red wire and checked both for corrosion, cleaned the terminals and the clamps with a terminal brush, then I scraped any grease or corrosion off of the round clips at the opposite ends and used terminal grease on all of the connections, put everything back as tight as an 18 year old virgin and still no dice.
It makes no sense to me why this is happening, I even ran and extra ground wire from the ground of the starter to the body of the car and it still wont turn, just clicks. |
#5 |
Where did you get your starter from?
It could be a bad solinoid on the new starter especially if its one from a chain store aka autozone There was a guy on here a while ago who went threw 3 starters before finding one that worked |
#6 |
had this problem yesterday when tring to start my old truck. turned out to be a loose connection. I also coat my batt termanal connections in copper grease so they won't corrode. as said before if it is off the chain stores it could be a faulty solonied(sp)
good luck with it
[COLOR="Red"]Lil' red islander[/COLOR]: 1989 Yj 33's on 15 x10 american raceing wheels with 3.5 Tuff country lift kit and 1.5 lift schackles. 4.2L ba 10/5 231 front d30 d35c rear flowmaster SOLD SOLD SOLD 1956 Willys Wag 327 chevy T90/D18 twin stick dana 25/ dana 53 1962 Willys P/U parts truck Chevy 350 [COLOR="DarkGreen"]1984 chevy c10 with sb 400, th350 hurst shift kit, hooker headers, eddy preformer II ntake, eddy thuinder 650cfm 4bbl,mild comp cam, polished and ported eddy heads, flowmaster super 40's[/COLOR] |
#7 |
I've narrowed down the problem with my starter. I got another replacement starter from advance auto parts, had the guy test the starter and it worked.
When I put that starter on and turned the key, same thing, just a click. So I got out my multimeter and started testing voltages. I get 12.56 volts from the battery. I get the same reading on the positive lead coming from the battery to the starter. I get the same coming from the battery to the fuse, and to the starter relay. When I tested the relay terminals I got the same thing, 12.56 volts. Here is what is driving me freaking crasy. When I test the line coming from the back of the relay to the other postivie lead of the starter (the one that gets 12v from the relay to crank it when you turn the key) I only got 10volts. So I traced that wire through the harness and found a short inside a connection plug near the alternator. The short melted the plastic plug so I bypassed the plug completely and just ran a wire strait from the back of the relay to the starter. I tested the line (while it was not connected to the starter) and, turned the key it read 12.56 volts. Here is the kicker, When I attach the same line that read 12.56 volts to the starter and turn the key it only reads 11.11 volts. Where is the voltage drop coming from? Why does the same line read 12volts when its not connected to the starter and 11volts when its connected. The starter needs the full 12 volts to kick over. I thought maybe it was because I wasnt using a copper wire at first so I went and changed the non-copper line to a copper line, no dice, still only read 11 volts, so I bought copper wire crimps to connect the lines at the splice, and I get the same reading. What do I have to do here? It shouldn't really matter what line I use, or what connectors, especially since the line tests 12volts when its not connected to the starter. Arg... |
#8 | |
Great analogy, prolly sig worthy. I had the same hapening in my YJ. It was a ground. I cleaned all connections, and haven't had a problem since. Dead cell in the battery? Doug
Wise men speak because they have something to say;
Fools because they have to say something. Plato |
#9 |
Got my eye on you.....
![]() Join Date: Apr 2005
Have you checked the firewall ground to the block? Just throwing that out there.
Congenital Heart Defects are a reality for me. Both of my children have one. Please read up and become aware!!!!!! Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#10 |
save yourself any more agrevation and just get new battery cables, those molded ends are where they corrode, went through this same thing on my bro's jeep a short time back, check the voltage at the starter while someone cranks on the key, you will see a severe drop. good luck
#11 |
Did you run the same size wire when you bypassed that plug. If it calls for 2 or 3 guage and you ran 6, then that could be it. If you ran the correct sized wire, then I have no clue.
1991 Red YJ - 2.5L 1996 White XJ Sport - 4.0L 1979 Multi Colored CJ-5 - 360 1978 Harley Davidson Shovelhead Stationed in Fairbanks, Alaska Soon to be Kuwait Then Undisclosed, Iraq. |
#12 |
I checked with my local jeep dealership and they want $112 for the cables! Anyone know anywhere else I can get them? I checked the local autostores but they have generic replacements and they don't come close in gauge or length to the originals.
#13 |
too much devils lettuce
on my starter there were socket welded to the bolts holding it on
that was a chuckle for me when i went to remove it
for sale: stock spare tire carrier, 87-91 smittybilt bed cover in black denim used a week, 92+ bestop bed cover, wind jammer, and bikini top. 90 D35. D30 axle shafts. 91 D30 bad r&p. 90 D30 w/out knuckles. 87-95 rear DS. CJ-7 full soft doors in black. 2.5L parts- ps pump, head, valve cover, push rods, water pump, fan can ship to paying members 1991 YJ Kabota orange, worked 93' 2.5L, 97' TJ AX5/NP231J+DS, 4" RC, 19lb injectors, E3 diamond plugs, 8mm wires, brown dog mounts, custom exhaust, optima yellow top, Ext Slave convr, Herculined in an under, 1/2 daystar shackles, sky jacker hydro shocks, 1 ton steering, bestop super top w/ soft doors, Centra-pod speakers, hella 500's, not many old parts left on it 1998 XJ sold 1990 YJ died |
#14 |
Replaced Cables
Just to recap thus far:
Problem: Jeep clicks when I go to turn the key the clicking noise is coming from the selenoid on the starter. Things I've done so far to try and fix it: Cleaned all terminals, battery terminals, + and - cable ends, sanded the body gound bolt, sanded the firewall + cleaned the torx bolt that connects all of the grounds to the firewall. Replaced the negative cable with a new one. Used a multimeter to test voltages around the battery. I get 12.5v on the battery and it retains 12.5v while cranking. I get 12v reading on the big lead from the battery + to the starter + terminal. Tested relays and they work. (swapped around the relays just to make sure) Tested the line coming from the back of the relay to the selenoid and found a fault so I replaced that Brown (normally greenwhite) wire going from the starter relay to the S terminal on the selenoid with a piece of new wire. Used copper crimps and copper wire. I replaced the starter, twice... I checked the engine to see if it ceased or something dumb like that, but everything turns line normal when I push it while its in gear. I cursed at the jeep, battery, fuse box, starter, and cables, but still no luck, it just wont start. ---- Tonight I'm going to try and jump it with another car, that way maybe just maybe its the brand new battery I just bought for it. Retest the starter just for funs sake. I'll take a look for a clutch switch but I highly doubt that has anything to do with it. Can anyone else think of anything it might be? |
#15 |
Could the starter gear be slipping from the flywheel? Just a thought.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Tale of an ARB install | LSU_TJ | TJ Technical Forum | 8 | 03-03-2009 09:58 AM |
| A tale of two Jeeps- which should I fix? | ctclark1 | YJ Technical Forum | 2 | 12-19-2008 12:33 PM |
| My YJ has gone through 3 starters in ~30k | HighandLow | YJ Technical Forum | 2 | 03-25-2008 06:06 PM |
| starters | dcfeeiv | TJ Technical Forum | 2 | 03-02-2008 10:16 PM |
| 90 4.2's eat starters? | wdhigh | YJ Technical Forum | 3 | 07-01-2007 11:01 PM |
The time now is 02:47 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
