Taking Suggestions, Please! - JeepForum.com
post #1 of 12 Old 08-27-2012, 05:05 PM Thread Starter
jth295
Alright, so I just recently got my dad's 1990 YJ, unfortunately it is not a V6 but considering I don't plan on doing too strenuous of activity with it, I believe it will have much potential.
Basically, this post is asking for opinions and important things I need to know when modding my YJ.
First off, I'm just going to make it clear that I am 17, a senior in high school, therefore I don't know all that much regarding Wrangler specifics, but I'm very interested in learning! I do work 5 days a week part-time and I save every penny I can(granted, it isn't a HUGE chunk of change), but I do wish to make my Jeep a project.
Now, to the good stuff.
I'm wanting to start off with the suspension, lift, wheels and tires first of course.
So far, this is what I have in mind:
4" suspension lift kit
2" body lift (at most)
33" tires & 15 or 16" wheels
Companies of these products and further ideas would help!
Now, I've read a little on trouble with the tires size in regards to I4 power and mpg. But, like I said, I don't know all that much.
Furthermore, I do not know what else I may need or want for my YJ, which is why I'm making this post.
I appreciate any and all help, thanks!
jth295 is offline
post #2 of 12 Old 08-27-2012, 05:14 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Don't worry, none of them were v6 from the factory. As for mods, the world is your oyster
Luck Favours The Prepared
Anticanman is offline
post #3 of 12 Old 08-27-2012, 05:24 PM
YJ4LIFE
1" BL, TJ flares, 32's you'll save alot of money
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #4 of 12 Old 08-27-2012, 05:29 PM
ltrail
1984 XJ Cherokee
^ this, if you NEED ~6" lift for whatever reason just get perches and start yours off by going SOA.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #5 of 12 Old 08-27-2012, 05:33 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Here's a suggestion: ditch the trackbar and swaybar and take it out to your local wheeling spot with a couple buddies in their rigs. Beat on it like it was eyeballing your old lady and figure out why you're getting stuck on which trails and see which modifications it will take to overcome these obstacles.
post #6 of 12 Old 08-27-2012, 05:33 PM Thread Starter
jth295
What about lift kit? I'm shooting for a pretty noticeable change.
jth295 is offline
post #7 of 12 Old 08-27-2012, 05:34 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
post #8 of 12 Old 08-28-2012, 12:04 AM
tdij
^^^Best build advice you will ever get^^^
I built mine... then wheeled it... then rebuilt it. Wheel first... then build to suit your wheeling preference and needs.
And rip out the track/sway bars for sure!
BOBCAT: TDI powered YJ
tdij is offline
post #9 of 12 Old 08-28-2012, 12:19 AM
chicalibro3
the first couple of bucks, you should spend on things to get it running like a top (i.e. fluid changes, filter changes, tune up,...). Once that is done, wheel it as is. If you have a jeep on 33s that runs like crap, you're gonna have a bad time. Waaay more important to have a reliable Jeep than a modded Jeep. Also, don't ask about anything (especially going SOA) until you have used the search feature.
chicalibro3 is offline
post #10 of 12 Old 08-28-2012, 04:45 AM
90DesertTanYJ
Your getting great advice here. The 2.5 does not really have the power and torque necessary to run larger tires without doing some gear changing and it already has 4:10s in it so there are only a couple of steps up (numerically). So if you want the lift to run bigger tires there will be other expenses in order to do this. Heed the advice here, find out what the 2.5 can do stock, start saving money last year, then decide what you need/want to do. Larger tires, 4" lift and a gear change will run you at least $2K unless you can get the auto shop at your school to help you out.
Oh and first thing, get under it and tighten the E brake cables and get rid of the brick.
90DesertTanYJ is offline
post #11 of 12 Old 08-28-2012, 07:10 AM Thread Starter
jth295
Thanks guys! I really appreciate all the help.
jth295 is offline
post #12 of 12 Old 08-28-2012, 09:39 AM
sdotcarter
Here's what I'd do.
I'd do a body lift first. 1.25". Then I'd do all fluids.
cooling system overhaul, new thermostat, hoses, Rad flush and fresh fluid.
Now with the body lift installed, I'd go through your brake and fuel lines. With the body lift that aspect will be much easier.
Then brakes.
Vacuum hoses.
Cowl seal.
check tires for wear, rotate as needed.
a good clean, including under carraige and wax job.
That's what I'd do before I'd consider going all out. Body lift is a piece of a good plan and it will help you in the hard to reach places.
sdotcarter is offline
1990 , mods , suggestions , wrangler , YJ
Taking off in first. ball0616 YJ Wrangler Technical Forum 7 04-06-2012 09:58 AM
Need help taking off the oil pan candid TJ Wrangler Technical Forum 3 06-11-2011 11:20 PM
Taking Suggestions on a Winch Bumper NavinRJohnson TJ Wrangler Technical Forum 2 09-18-2006 03:48 PM
taking the top off? H4D13Y YJ Wrangler Technical Forum 4 05-18-2006 06:35 PM
Taking off my top? grantnps YJ Wrangler Technical Forum 2 10-14-2001 08:27 PM
