Quantcast Taking pictures during disassembly? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Taking pictures during disassembly?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 06-16-2007, 11:21 PM   #1
JGBrown
1995 XJ Cherokee
Anyone else do it?
I've got a little water proof digital camera, best tool for fixing the jeep IMO, I can take pictures and go to the parts store, take pictures while I take stuff apart, take pictures of the bits laid out, and then have a reference when I put it back together, I forget whenever I go to work because I don't get back to it for 4 days.
JGBrown is offline   Reply With Quote
Old 06-16-2007, 11:23 PM   #2
Tomb Raider
MyJKRocks!
I have, literally, thousands, of pics from my engine and drivetrain swap. Just so I know where everything went before I tear into it....where wires go, where connectors, hoses, yada yada yada.
2007 JK Unlimited Sahara
37" Irok ND's
4" rough country lift
Tomb Raider is offline   Reply With Quote
Old 06-16-2007, 11:28 PM   #3
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
I with ya', I'm a pic whore too.
Joe Dillard is offline   Reply With Quote
Old 06-16-2007, 11:35 PM   #4
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
not quite this crazy, but it did save my *** when i did my locker and forgot to match mark the ring gear before i took it off.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote
Old 06-17-2007, 05:10 AM   #5
JGBrown
1995 XJ Cherokee
and on that note, whats the dumbest or worst thing you've done to your camera so far?
mine went into the tub of nasty ATF from the T-case
Old 06-17-2007, 05:10 AM   #6
JGBrown
1995 XJ Cherokee
double post
Old 06-17-2007, 05:44 AM   #7
JGBrown
1995 XJ Cherokee
Double post
Old 06-17-2007, 06:40 AM   #8
schwim
Technically, that last one's a triple post.
I usually use pics to get my point across to either the parts shop or on a support forum. I usually remember reassembly details, but often fall short on trying to explain something to someone else. For this, the pics are priceless.
thanks,
json
schwim is offline   Reply With Quote
Glock Forum
