Taking out the "factory" AC - JeepForum.com
post #1 of 9 Old 10-04-2001, 05:00 PM Thread Starter
Brendan
My jeep came with, or had the aftermarket AC kits installed on it. I want to take it all out. I was just wondering what was involved with taking it out. My alternator comes off the AC, so I was wondering what I would do about that. If any one has an 87 - 90 I6 wihtout AC I'd love a picture of the left side of the engine bay, where the alternator resides.
I want to take out the unit inside the cab to, not just disconnect. Thanks
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #2 of 9 Old 10-04-2001, 10:51 PM
bob91yj
Stop, leave the compressor right where it is. You have virtually instant on-board-air.
You can scrap the vents, condenser, etc if ya want, but you will regret removing the compressor one of these days.
I'm not sure what the etiquette is here about refering to other sites, but I know there is a how to for OBA at www.jeepaholics.com. It's in the tech forum.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #3 of 9 Old 10-07-2001, 07:44 PM
osburn
osburn's Avatar
Yeah! What Bob said for sure! Perfect onboard air setup dude. Toss everything else, but leave that compressor right where it is and plumb it for air! You'll be so happy you did.
Matt Osburn
Score 1032
osburn is offline
post #4 of 9 Old 10-08-2001, 07:17 AM
glm 87 wrangler
First I agree with the others for on board air but if you really want to remove it here you go. First make sure there is no freon in it. rember there are laws about that but what you do is your business.But if there is not start removing srews and bolts,and if no freon is in the system and the unit is totaly
shot,start cutting away hoses and wires be carefull there make sure all the ones go to the unit just start tracing them from the unit it self make sure you tape off bare ends better yet if there is a fuse that dedicatedto the AC like mine just remove it.AS for the compreser if you take that off you will need a shorter belt you can take your old one to the auto parts guy should be able
to estamate or use a belt for the non AC jeeps may work but the shorter belt should not be a problem to find you can always go back until you find the right size they will exchange it I did this before.Hope this helps
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #5 of 9 Old 10-09-2001, 07:52 PM Thread Starter
Brendan
What Do I need air for? I don't mean to be a dick, i mean it literally, I'm pretty new at this. I don't have a lift yet, and I don't want an ARB locker. I would love to have a cool setup with air, but what would I use it for, and how would I rig it?
Duvie
95 YJ 2.5L 5 Speed
Brendan is offline
post #6 of 9 Old 10-09-2001, 08:24 PM
bob91yj
OBA (on board air) can be used mostly for airing your tires back up after wheeling, running air tools for trail fixes, etc.
You may not think you need it now, but if you stay in the sport for long you will. I wanted it after watching someone with it air up 4 tires, while I was still on my first with a 12v compressor.
Check the Tech Papers section of www.jeepaholics.com for a how-to article on the install.
Bob
bob91yj is offline
post #7 of 9 Old 10-09-2001, 08:29 PM
JeeperJay
This sounds like a damn good idea! How much PSI does a AC compressor put out? Just wondering.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #8 of 9 Old 10-09-2001, 09:09 PM
Pantera
Most systems are set up for about 120 PSI... I think the average compressor can put out more than that though I'm not sure how safe it is...
Eddie H.
91 YJ 4-Banger
Omaha, NE
Pantera is offline
post #9 of 9 Old 10-11-2001, 08:02 PM
bob91yj
You need to install a pressure switch in the system to prevent over pressurizing the system. 90 psi is probably the industry standard for air tool operation.
The pressure switch needs to be wired to the A/C compressor clutch so that it disengages at the specified pressure. A pop-off, or relief valve in the system is a good idea too.
Bob
bob91yj is offline
2010 Factory Radio "Media Center 130" Wiring Diagram? pennstump JK Wrangler Technical Forum 6 02-09-2010 12:47 PM
Taking Off Stupid " Trail Rated " Emblem Nick B TJ Wrangler Technical Forum 47 10-16-2006 12:24 PM
"clunk" when taking off in 1st or 2nd txpedro TJ Wrangler Technical Forum 17 09-12-2006 10:40 AM
Factory Side Step "Nut-serts" in Frame Supercharged99TJ TJ Wrangler Technical Forum 5 08-11-2005 08:28 AM
Problems taking off bumper"front" Steve28 YJ Wrangler Technical Forum 5 09-28-2004 10:56 AM
