Tailpipe bracket rusted through. clean up and weld? - JeepForum.com
post #1 of 5 Old 04-16-2010, 03:30 PM Thread Starter
kdougmorse
I was planning to knock off the rust on the tailpipe and paint it, but I noticed that the little pencil-sized metal bar that helps hold it to the body has rusted out/through the pipe in this section (right underneath the rear bumper). I'm overseas, so shipping a new part via USPS is probably not gonna be possible due to size restrictions.
Would stripping the rust and welding fresh metal over the hole/holes be worth it? It doesn't have to look good, it just has to work for a while.
August 2011, and I'll be back in the USA!
kdougmorse is offline
post #2 of 5 Old 04-16-2010, 03:56 PM
Leans93
She's my density...
Leans93's Avatar
As long as there's enough good metal left to weld to then that is what I would do also is just weld it back up.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #3 of 5 Old 04-16-2010, 06:33 PM
Fhajad
Weld it up and use some rust prevention spray paint or something.
Fhajad is offline
post #4 of 5 Old 04-16-2010, 08:38 PM
K4KAS
You could also move the hanger forward or back a bit to get away from the rust hole.
K4KAS is offline
post #5 of 5 Old 04-17-2010, 03:49 AM Thread Starter
kdougmorse
Would it be a fairly easy job to take the pipe off the rig without using a lift? If so, the plan is to take it off, clean the rust off and see just how bad it really is, then buy some steel and take it to the welding shop on base.
If I run without the tail pipe, is it going to be excessively loud?
Rusted Sway Bar Bracket...New New One dbdragracing YJ Wrangler Technical Forum 8 01-04-2010 01:10 PM
BRAKE LINE BRACKET RUSTED any help? hdnva YJ Wrangler Technical Forum 2 12-07-2008 07:19 AM
Tailpipe Hanger Bracket gazeux YJ Wrangler Technical Forum 6 11-09-2006 09:53 AM
Need Help on Broken Tailpipe Bracket sc1972 YJ Wrangler Technical Forum 4 06-01-2006 02:44 PM
8.8 bracket weld locations… TJSilverSport02 TJ Wrangler Technical Forum 2 06-09-2003 10:40 AM
